Dead Time - Correcting for it
sdinfo (John?),
. . . and is just sucking information from DiyAudio to post on HomeTheatreHiFi". That may portray you as quite shallow, and may do you no favours . . . .
. . . On your site, I see that you reviewed the $42,690 Lamm preamplifier, which you describe as " I will use a noun: Magic. I have never heard anything like it before, and I suspect I won't encounter it again". Well, if you can get past reviewer bias, elitist image, and marketing hype, I offer to build you a perfectly presented clone for just $20,000. In a double blind test I guarantee you will not be able to separate them, and you'll save $22,690 !!!
Now that must surely be the bargain of the year...
...any takers???
I definitely would not be sucking information from diyAudio, and $20,000 is probably near the wholesale cost to the dealer. So, no takers at this end. But I will get the Morgan Jones books, because several of you have suggested them. I'm done here. Thanks for the info, although it was not very much.
