+1Scroggie starts from basic science and builds a knowledge of electronics on a solid foundation. I studied that book when I was a teenager.
Also, it was Scroggie who set the bar for clear technical exposition and excellent writing, not Jones!
sdinfo (John?),
. . . and is just sucking information from DiyAudio to post on HomeTheatreHiFi". That may portray you as quite shallow, and may do you no favours . . . .
. . . On your site, I see that you reviewed the $42,690 Lamm preamplifier, which you describe as " I will use a noun: Magic. I have never heard anything like it before, and I suspect I won't encounter it again". Well, if you can get past reviewer bias, elitist image, and marketing hype, I offer to build you a perfectly presented clone for just $20,000. In a double blind test I guarantee you will not be able to separate them, and you'll save $22,690 !!!
Now that must surely be the bargain of the year...
...any takers???
I definitely would not be sucking information from diyAudio, and $20,000 is probably near the wholesale cost to the dealer. So, no takers at this end. But I will get the Morgan Jones books, because several of you have suggested them. I'm done here. Thanks for the info, although it was not very much.
You've certainly been gracious and appreciative throughout.
