DD Z1a damaged
The Frequency increase every more winding. I have now about 21khz.
Picture above is Highside
I removed the chinese parts and left only a few from the quality parts. After switching on, it draws a lot of amps, because the bulbs lit very strong. In that same moment the speaker made noise again and some smoke came from the drive board. So will order parts again.
Only for my understanding, how that Amp produce audio.
Low side makes negativ voltage and high side positive voltage. If both sides in balance there is no audio. If they are unbalanced IT produce audio. That means, that the noise what i had is from unbalance from both sides.
Is that correct?
