Hello everyone I have long sought help to repair my two DCX2496 but even though I tried I did not succeed I read that you just need a functional eeprom dump to run again cast aside my DCX2496 ask please help who can assist me sending me an eeprom dump v1.17 v1.16 and other functional because it really is what I need and I could encotrar who can help me in this case agradesco beforehand who or who can assist me with my problem mail is spukiraz.90 @ gmail.com ........ regards
Hello,
i also look for a DCX Flash Dump 1.17 or 1.16 for my dead DCX 2496 too reflash with my eeprom programmer
i hope some people have please pm
regards Zeno
hello, i can sell for eeprom DCX2496 already programmed solution to your problem.
This was announced in: Dcx2496 Behringer Flash Eeprom V1.17 - R$ 220,00 no MercadoLivre
Renato renatoloks@yahoo.com.br
Eng. Eletroncs
Brazil
me puedes explicar mejor el procedimiento para poder dar solución a el problema con mi dcx2496 no actualiza, pantalla verde sin nada.
gracias
email: jluis.hp@gmail.com
gracias
I have the same problem with the DCX2496, green screen,
does not allow firmware update
I thank you send me the solution to the email:
me you can better explain the procedure for a solution to the problem with my DCX2496 not updated, green screen with nothing.
thanks
English please.
dave
I have the same problem that is described, not my DCX2496, green screen goes unlearned, I try to update it with the original program goes berhinger connection error. Could you send me the solution? or guide me how to do
thanks email: jluis.hp @ gmail.com
Hi I thing I have some EPROM backups. I will send it to you.
good,
have the original files eeprom DCX2496?, I have the chip in white, and the developer, it would send me to my email?
Hello!
While there was a power upgrade and died the DCX2496?
Q: I buy new EPROM (blank) I will include refreshments and improves the EPROM writer MUST OR ?????
Thank you!
Thank you!
he buscado el archivo Xover.bin sin exito
he buscado el archivo Xover.bin sin exito alguno, agradeceria si alguien lo subiera, desde ahora un millon de gracias
Hello to everyone in the future googling this problem... (shoutout to denvercoder9)
I just did the same thing to myself - got an old dcx2496, "oh it's on 1.14 let me just put 1.16 on it" of course that was stupid.
As per everyone else's results no luck using a usb-serial cable, hangs at 1%.
When I disabled FIFO buffers in the driver settings it was then able to upload up to 45% but still again hangs.
HOWEVER there is hope!
Using an old laptop with a hardware serial port, I successfully uploaded the 1.16 firmware using 1.16a Remote software. (Software package here: Behringer DCX2496 Failed Update Recovery - LA2YUA)
Using the recommended serial port settings did NOT work - it would upload but hang at 90%.
After trial and error on all of the following changes, I finally achieved a full upload and a WORKING DCX2496 without flashing eeprom!!
Baud: 9600 (not 115200 as recommended)
Data bits: 8
Parity: none
Stop bits: 1
Flow control: Hardware
Advanced settings: Un-check Use FIFO Buffers
All of these changes together seem to be important as no other combination resulted in success.
I was also using a fully wired (all 9 pins) DB9 serial cable, not a 3-pin 'minimal' cable.
Good luck!!
Data bits: 8
Parity: none
Stop bits: 1
Good luck!!
I also managed to get my DCX back to life, helped by @Bluefusion tips. I successfully uploaded the firmware using with a 1.16a Remote software, with a USB to 9-pin serial Prolific adapter on windows 7 x64.
As addition to the previous mentioned tips, to overcome the 45 and 90% hangout I used a 300bps transfer rate and 512 bytes driver buffer size.
I have to mention that during the firmware restore, my presets remained intact.
Good luck to all!
Good luck to all!
Hi guys,
I fell into the same trap as most in this tread, try to update first and once it fails check out the forums
Is there anyone with the 1.17 eeprom dump so that I can flash mine again?
Thanks!
Dennis
Thanks!
Dennis
DCX 2496 UltraDrive Pro
Hi!
Today I thought I’d put an update on DCX, but something went wrong and everything goes there.
I think the whole system got there too, because after booting the logo comes in and then nothing happens, the logo disappears and it’s done.
I’ve been suffering from it for a few hours now, but I haven’t gotten anything.
Unfortunately, my English is pretty bad, but I hope it can be understood that way.
Hi!
Reviving this old thread to ask the obvious question...so the consensus is I just leave my DCX2496 on 1.14? Is there any known genuine advantage from the later firmware? I must say one thing that doesn't play nice with this older model is the DuinoDCX remote. It causes the ultradrive to freeze although I'm unsure if it's just the fact that it's the older model or the firmware.oh it's on 1.14 let me just put 1.16 on it" of course that was stupid.
- Digital Line Level
- DCX2496 update problem
