DCX2496 update problem
Account Closed
Joined 2001
Well, I don't understand. Your unit had FW 1.17 installed, but you decided to "upgrade" to 1.16.....that process got messed up and now you want to "downgrade" back to 1.17?....which is what you originally had.
Possibly this new FW 1.17 requires a new GUI program just as FW 1.16 did? A new GUI which is not available yet and might be the reason FW 1.17 is not on the Behringer website yet?
I think you better leave well enough alone. :)
Dave.
Thanx. Seems i don´t get access to this yahoo-group. Signed up, but it keeps kicking me out when I want the web features enabled. Do I need an invitation?
Did aynone already try upgrading old DCX to 1.17 ?
Yes I did and now am super bricked. I spoke to Behringer and they claim the firmwares are the same with the exception that 1.17 is for a newer board revision IC (maybe the eeprom?) I was told by someone else that the 1.17 posted is a full dump and as such needs to be programmed via eeprom programmer not RS232 > DCX.
a solution to this problem ? USB 1.0 because the buffer data transference is lowest than 2.0
1- turn on the DCX2496 pushing the left key
2- conect to the pc
3- use DCX2496_remote_1_16a NOT HIGEST OR LOWEST, THIS
4- install first Xover.bin file
5- restart the dcx
6- now you can use it
7-restart again pushing left key to update again
8- conect to te pc and soft
9- install DCX_116.bin file
10- restar when finish and now you can use it full
Best regards
GABRIEL VILLA, Mdz. ARGENTINA
I recently purchased a Behringer DCX2496 and was amazed at how well it
performed. One week later I decided to upgrade the firmware with the same
usb-serial adapter I had already be using the remote software on but it did not
complete.
I now have a unit that will only display the power on screen "Behringer
DCX2496".
Any and all help would be appreciated. I really would like to get it working
again.
We used to program eeproms at work so I can go down that road if need be.
Please help lol.
