Thanks Markus,
but I need a solution without soldering inside the DCX.
I will try a simple voltage divider a la Sengpiel put inside the XLR jack.
Rudolf said:Thanks Markus,
Thank you guys, Markus and Rudulf for your effort and information. To connect DCX2496 to HiFi gear seems not so easy to do "right" then - hum...?
Although this is diy Forum, my capabilities is limited to more or less to the speaker's wood-working part and as for "electronic diy" I am afraid I must depend on others. It also means that any soldering inside the DCX would be over my head I am afraid.
There must be hundreds of people using DCX2496 with HiFi gear and same as I do just using simple XLR/RCA plugs for connection. I would be glad learn to learn even any "less worse solution" (compared to simpe plugs) if such solution would be of improvement. I made quick search in th gigantic DCX2496 thread and maybe below post is similar what Rudolf mentioning..or.?
#post202
Hi !
Another solution is to implement a dividing network on each of the outputs.
I use 20db attenuators made of two resistors soldered into the XLR connectors : 10Kohms in series with signal pin and 1Kohm between signal pin and ground pin.
This is called also a T-pad : Attenuator calculator or even Another calculator
It is very efficient, cost is close to zero (a bunch of resistors can be bought for a few cents) and it works a treat !
Thierry
Best
LageB
Here's how to DIY:
http://www.dcx2496.fr/en/tweakanalog1.php
There's also a plug & play kit by Selectronics:
http://www.selectronic.fr/dcx2496_US.asp#04
Markus,
I don´t want to invest that much money in my DCX.
I tried that 10/1 kOhm attenuator in the XLR connectors (plenty of room inside 🙄 ) and it makes a substantial difference. To play it real safe I will change to 20/1 k in the long run. That will keep input voltage at the AV receiver below 0.3 V all the time.
There's an unbalanced crossover from Sitronik:
http://www.sitronik-industrie.de/frontend/dyn,pmode/eshop/shop.php?rub=h8&sub=34kanal&shopy=
Best, Markus
Best, Markus
