DCX2496 and volume control
Hi and good site: www.dipolplus.de 😉
I'm constructing dipole speaker too...
About DCX volume control, I have design the pcb for this Alps pot and replacing dc coupled capacitor by Nichicon muse 220uF/50V caps themselves bypass by styroflex type caps.
I can only give you a .pdf with the circuit board because my HD failed 😡
The control have been done during a time with a simple
I'm working on a simple pcb with two push button and ir receiver allowed remote volume control.
Sorry for that failure. 😱
I would love to get that pdf. But if you will have that pcb with IR control ready in a foreseeable future, I would be happy to buy a spare pcb of that from you.
You find my email adress at dipolplus.
Some last questions about your actual solution:
Where do you take the power supply for the motor (blue/white wire) from? And where is the white (ground?) wire leading to?
Thanks for helping
Rudolf
Sorry for my too big pics attachement!!
Good question Rudolf 😉
The white ground wire goes to the ground line under the output pcb of the DCX!
The alimentation of the pot is only plug on three positions, two ways no permanent switch, but I'm already working on the IR solution. The switch is outside the DCX and I use the power supply of he DCX.
