DCN23BOX Digital Crossover/EQ/Room Correction - Stock Clearance Sales
Offer: DCN23BOX – 115Vac version.
DCN23BOX product page
High performance Digital Crossover, EQ and Room Correction in a very nice ALU chassis toned acrylic front panel.
The product features 2 XLR balanced inputs and 3 singled-ended RCA outputs. The unit has 3 processing channels with 16 full-freely configurable biquads each. Free setup software
Only 4 pcs of this nice product is left – It can be yours for only 330 USD á piece including shipping with normal postal service to US or Canada. Please contact salg at groundsound dot com for more info and purchase.
Thanks, Shaun.
Well if you have the option of precise PEQ in a digital crossover then you got the possibility of attenuate the room modes, which is the important part of room correction.
The software do not have the measurement and analyser engine built in so you have to acquire the parameters (frequency, Q & gain) for correcting your room in another way. The DCN23BOX hardware has the precision for room correction that is required so does the DCN23kit have that you own.
/Robert GS
I don't understand your outputs - a normal stereo bi-amp setup with electronic XO needs TWO outputs for each channel, (hi-pass & low). Yet yours are labeled 1,2,3+, 3-. Why is it labeled like that?? Are there 4 separate outputs that correspond to a standard setup or not?
Don't be confused...
There is 2 inputs and 3 outputs - "output 3" is both non-inverted (normal signal) and inverted. This makes it possible to drive the bass or whatever you connect to "output 3" in bridgemode if you want. It requires a stereo power amplifier that isn't already in bridged mode.
I don't see that I in any point claim that DCN23BOX is capable of stereo hi- & low-pass out. Where did you read that?
Bonus info: The DSP "onlY" holds 3 processing channels.
Best regards,
Robert GS
