DC filter
Read my posts again. Now, did you see "safety earth" keyword anywhere?
No, this keyword I don't read. OTOH - if there are no "Neutral" mains connector at your home, means this for me at the same time, that there is no "safety earth" in use. Otherwise there must be a "Neutral" mains connector present.
Ah OK, so you belong to the "very old systems" 🙂
I´m stll using my balanced AC system with a 2 x 115V transformer to avoid DC and add some filtering. Works fine.
William
Do you create your balanced AC system with help of an isolating transformer?
the elcos only need to be 16V or so. They will never see more than 1,4 volt if you use two diodes. And even if you don´t the voltage is very low if the capacitance is high enough.
Read post #16 from the thread mentioned above, here everything is mentioned correctly.
William
OFFTOPIC: can anyone drive me to where my problem is discussed?
A buzz in the output, that comes and goes, clearly due to an external source, from outside of the place (maybe some neighbors' appliance).
My set is an amp with built-in mixer, and this bothers me a lot while using the microphones.
I have noticed that earth settings are very important in this case, and I need to review my setup.
Thanks a lot.:hohoho:
A little safety warning
:cop:
It seems a little safety warning is in order.
I will, thanks. How about simply two elcos of 400V 560uF in parallel? If there is higher DC then 2X forward voltage, that should take care of it for sure? I got two from a switcher PS.
I meant without the diodes - just two caps in parallel. Then I remembered that they are rated 420VDC for forward voltage only😉
Potential very dangerous... don't even think about it !
even without diodes the voltage over the caps only depends on the current that flows and the inner resistance (ESR?) of the caps. Normally it should be very low (lower than 1 Volt).
William
Suitably rated diodes are the circuits safegaurd. It MUST be safe under all conceivable conditions, fault or otherwise. What about startup. What about one cap changing value or going high ESR ?
It must have been linked to several times but this covers it all,
Mains DC and Transformers
:cop:
It does not work for me, with or without caps (in series). With snubber on both secondaries, it gets even worse!
I will try to put two dc blocker sets now, that should block up to 3V I guess.
Why are we all assuming that everyone has DC < 1.4V on the line? It could be much worse in my case.
Perhaps you have another issue. If you measure the DC voltage across the two caps you should get some idea if there is DC there or not. But be careful... remember the diodes and caps are live.
Well, I removed all filters and snubbers, and hum has gone down significantly😉
If add/remove them few more times, it might be completely gone😉
It seems I do not have any DC at mains after all. The faint "purrr" I hear is probably due to PCB being too close to toroid. It might make sense to separate them with steel plate, but that's a project for New Year. Speaking of which, marry Xmas and Happy New Year everyone:clown:
I had a similar issue with a power amp and the cause was incorrect grounding. It took a lot of thinking over what was happening but eventually a 100% fix was found. As the mains "quality" varied a very noticeable buzz appeared on the audio output. A scope check showed the presence of tiny pulses of data on the mains when this occured... some form of mains signalling somewhere and always at the same times of day. Its a residential area and I've no idea what they were unless possibly generated by the electric company (they were looking at developing broadband via mains wiring but it never came to anything).
You would have to read all this starting around post #8
http://www.diyaudio.com/forums/solid-state/101321-3-stage-lin-topology-nfb-tappings.html#post1617990
