This unit is now available:
8 ohm version available too
Does anybody have any other measurements on this driver?
I'm probably going to end up buying and measuring it anyway, it's dirt cheap.
Thoughts?
Dayton Audio DMA90 - 3.5" Full-rangeResonant frequency Fs 88.2 Hz
Surface of the diaphragm Sd 38.5 cm²
Effective diaphragm diameter Ø 7 cm
DC resistance Re 3.8 Ω
Mechanical Q Qms 2.50
Electrical Q Qes 0.56
Total Q factor Qts 0.45
Efficiency bandwidth product EBP 157
Suspension equivalent air volume Vas 2.265 litres
Suspension mechanical compliance Cms 1030 µm/N
Moving mass Mmd 3.1 g
Moving mass (including airload) Mms 3.2 g
Mechanical resistance Rms 0.7 N·s/m
Force factor BL 3.5 T·m
Voice coil inductance Le 0.3 mH
Maximum linear excursion Xmax ± 2.5 mm
Displacement volume at Xmax Vd 9.6 cm³
Efficiency η₀ 0.27 %
Thoughts?
Did you ever measure this driver? I am curious about distortion performance...
Another forum member recently posted dipole FR measurements on the 4R version here:
back wave in comparison to front wave
