Daphile seems to invert my left and right channel
Does this happen with all file types or one particular? DSF? DFF? Are you using DSD-over-PCM?
I tested different files formats and also DSD-over-PCM but I didn't manage to repeat the problem. The test files that I used can be found at http://www.daphile.com/SpeakerTest/
No problem for me for FLAC, WAV and MP3
DSD files not tested (my DAC is not DSD Ready)
Toufik
Toufik
I tested different files formats and also DSD-over-PCM but I didn't manage to repeat the problem. The test files that I used can be found at Index of /SpeakerTest
It happens to all kind of files, except DSD as I don't have any sample file yet. I noticed this problem when I played "Lazeez" from Acoustic Alchemy, there's a maracas sound on the right channel on the beginning of the song. I'm so sure as I hear this song everyday on my car. With Daphile, the same sound appears on the left channel. I have to swap the input on my amp to make it sounds correct.
BTW, about USB-3 problem : I've tested on a motherboard with onboard USB-3 (MSI AMD E350IA). Amanero works with USB-3 and I'm currently listen to it. The previous problem with Intel DN2800MT board seems caused by the use of add-on USB-3 PCI-e card (Nec/Renesas chipset). The sound with USB-3 is fuller than USB-2.
I'll test with your file & let you know the result. I'm going to test the wifi hotspot as well. BTW, do you get the feedback I sent through your website ?
Update: Daphile recognizes my USB wifi dongle but wifi hotspot doesn't work.
I also able to reproduce the problem with shutdown failure I've reported before. It happens only when shutdown is triggered while music is playing. Shutdown is OK when the music is stopped.
There's option to share the storage, what is the protocol ? SMB or NFS ?
Other update: all the test files works perfectly without have to swap my amp input. So either my brain or my car stereo needs some fixes.
So for me, it remains the problem with Amanero + add-on USB-3 card & wifi hotspot
Please send the exact model of the add-on USB-3 card and USB wifi dongle. And also the Linux driver module that they require if you known.Other update: all the test files works perfectly without have to swap my amp input. So either my brain or my car stereo needs some fixes.
New version available!
CHANGES on October 18th 2013:
Update via your Daphile web UI or download from www.daphile.com.
Any feedback is warmly welcomed!
- First 32bit x86 release for i486 and above
- Composer (available only for classical music) and Label tags for ripping
- Shutdown and restart button to main menu
- TRIM support for ext4 SSD partitions
- WLAN HW switch detection (RFKILL; "Connect Wi-Fi: HW switch disabled")
- Bug fixes (eg. some DSF playback fixes) and minor changes
I downloaded the new 486 iso and have tried to get it working on a usb drive. Followed all instructions using unetbootin, everything seems to install properly, but when I reboot and the menu comes up, I choose Daphile it looks like it is loading but the screen just remains blank. Not sure what I am doing wrong?
First thing that comes to mind is that your PC does not support the boot graphics mode that Daphile is using. Did you try if you could connect to it with the web browser? Daphile does not have anything special on its local UI, just some information when it has made network connection and it's not possible to use Daphile through the local console.
Hello, i tested Daphile tonight using an Atom board and a behringer uca202 DAC.
On the same atom board I used voyage mpd for about a year.
I think daphile is really a good product and I must say a big thank you to Kipeta.
The web interface is well done and the configuration is really easy and intuitive.
The only problem i encountered is WiFi. My little USB dongle doesn't work, I can't access the hotspotmode nor I can connect to my WiFi router.
My dongle is a 'digicom' branded one and uses the realtek chipset.
Do someone knows a USB WiFi dongle that works well with daphile?
Federico
Federico
Hi Federico,
I have the same problem here.
I you want, you can use the Netgear WNCE3001
It´s connect to RJ45 plug and powered via usb or
AC PLUG. This modul give you access to 2.4 or 5Ghz band.
I will get two dongles today. Will test it and report
If working or not.
Toufik
If working or not.
Toufik
Hi Toufik,
If I find a wnce3001 locally I'll buy one.
If I can't I'll buy some random USB dongle hope for the best and report..
Bye
Federico
Bye
Federico
Hi federico,
I tested one USB dongle it's an Xtreamer with a small antenna (latest model with RT3070chip ) It's seems working fine work with Daphile. Should test later if Hotspot work with this key.
Will test tomorrow the Netgear module to check the performance in 5GHz band insteand the Xtyreamer Dongle.
Toufik
Toufik
Thank you, I didn't found thath netgear product locally so I'll try some USB dongle. Thank you for your tests
CHANGES on October 24th 2013:
- Fix the playback of music with sample rate not support by audio device
- Include the staging WLAN drivers
- Kernel minor level upgrade
- Bug fixes and minor changes
After reading the Daphile threads on diyaudio, computer audiophile and hydrogenaudio I have not seen one single user comment about sound quality. Could someone who has used Daphile please comment on this?
Peter
Peter
- PC Based
- Daphile - Audiophile Music Server & Player OS
