Use cifs, it´s work for me with my DS112+
Toufik
Im not familiar with linux
What path do i have to put in?
NAS/music
Install on an internal HDD?
Would it be possible to make the installation "permanent", i.e. to install to an internal HDD?
Or (even better) to an internal CF card? I have a "thin client" computer with an internal CF card, and I'm not sure how I could install on the CF card...
Any ideas?
Any ideas?
NAS/music
Basic format for CIFS "Remote target" configuration is
username@server_name_or_ip:/share_name/directory_path
username and directory_path are optional. If you don't use username you can also drop the @-character.
example: 10.0.1.2:/shared/music
"Identification" could be any alias name.
You can leave password empty if your server does not require it.
Any ideas?
Just go to Settings -> "System Firmware" -> "Select target disk".
Disk must be completely empty (no partitions) or it must contain DaphileBoot and DaphileData partitions in order to be enabled for installation.
Currently I'm not able to say if installation to CF is supported (I don't remember if CFs behave the same way as USB flash or harddisk in Linux). See if CF is visible in the target disk list.
Hi Kepita
I think Daphile is wonderfull. Tried it on my laptop and worked perfectly. Later on I used the same USB drive on my mediaserver HW and it would boot but then is showing a banner that the media is read only. I checked the USB drive and it is OK.
Would you know what this can be?
How did you install the USB flash? Did you use unetbootin? Did you use the latest version?Hi Kepita
Can display the kind of music playing for ex. DSD64 or PCM192, etc.
Web UI Audio Player development is still on quite low priority for me. That's because I prefer the tablet apps (like iPeng and SqueezePad) for music control.
Daphile works very good for me. Remote over Android App and an old IPod Touch via iPeng works flawless.
All i miss is a Eq. If possible a parametric equalizer.
Is there such a plugin or can it be done in another way?
Thanx for the good work!
Andreas
I'm currently not aware of any. I have read something about BrutefirDRC but I have understood that it's not possible to install it easily through the LMS Plugins setup interface.
I have considered to include some kind of feature for digital filtering with brutefir but I can promise anything there yet.
I used unetbootin, latest version. Same combo is working on my laptop without issue and the write protect issue poppes up at my media server.
Used unetbootin to create a fresh USB drive each time.
Just to make sure that is it the same USB stick and same install that works on one PC OK but on the other it is read-only? And is it repeatable?
Is there a file named "casper-rw" in the root directory of USB drive? If yes what is the size?
I tried to update the software using the Daphile web interface but cannot find the right menu/button to do so.
Peter
It's located in "Settings" -> "System Firmware".
Note that the unetbootin installed (or Linux dd installed) USB Flash version of Daphile does not support firmware update.
Very nice, I like it!! Simple and clean, works with my DACs. I need to figure out the filesystem stuff though. My whole network is SMB and does not support NFS. 8TB of tunes on it now... I'll let you know what I come up with. Thinking of small linux box that can mount the SMB and serve up NFS...
Use CIFS. SMB and CIFS are pretty much the same.
Update available
CHANGES on November 9th 2013:
Any feedback is warmly welcomed!
- Bug fixes for CD ripping, multitrack FLAC+CUE problem & NFS mounting
- Multitrack FLAC+CUE problem fix requires "Clear library and rescan everything" rescan (Info tab)
- CD ripping FLAC compression level setting added (default:5)
- PC Based
- Daphile - Audiophile Music Server & Player OS
