Not quite exactly DRONE7, but when I followed your instructions to the letter it worked on WIFI dongle beautifully.
Thank you very much for your help. Daphile is a brilliant system for me and is now perfect. Thanks again.
thyristor44
Also use a static IP address for ongoing connectivity continuity within the browser. You can also use "//<daphile network name>.".
Thanks, I will.Also use a static IP address for ongoing connectivity continuity within the browser. You can also use "//<daphile network name>.".
@Triplefun.. yes and if not using a static ip address Firefox should do dns resolution so typing "daphile.local" without the quotes into the address bar should navigate the browser to Daphile.
Otherwise use the free Fing app on your android phone to discover the ip address needed to type into the browser's address bar..😉
Fing - Network Tools - Apps on Google Play
Hi all.
Been using Daphile for a while and it's been going well except I seem to have overlooked one thing… I'm not getting gapless playback on mp3 files. FLAC, yes, but mp3 will have about a 1/2 second gap between tracks.
Is there a setting somewhere I might have missed (I've pretty much left most of the settings at default)?
Cheers. (sorry if I've been too vague about my current settings. let me know if you need some more info)
Hi all.
Are you upsampling the mp3 tracks compared to the flac processing?
Issues with bits display
Hi ,
I wonder if someone can enlighten me on why it is that when i play a 24bit file Daphile shows this correctly but when it feeds my Topping D50 DAC this shows 32 bit ????
CV
Hi ,
CV
Your file contains 24bit samples, the player knows how to read them and therefore displays 24 bits.
Very likely your DAC reports during USB handshake that it supports only 32bit samples (plus possibly 16 bits). I could not find details for D50, but for its sibling D30 it is available Volumio won't play DSD native : Help - Page 3 - the stream0 file tells it all:
As you see, D30 supports only S16_LE, S32_LE, and DSD (SPECIAL format).
Its sibling DX7 supports at PCM only S32_LE (+ DSD):
S32_LE support instead of the technically complicated 3-byte S24_3LE is very common in soundcards, many PCI(e) cards do it like that too (Envy24, Xonar).
Therefore the driver (basically the alsa device hw:X) tells the player in daphile linux (software squeezelight) "hey, send me 32 bits (or 16 bits if it supports, I do not know)". And the player must comply by converting the samples to 32bits by appending the extra 8 bits.
The DAC does not know the original resolution, it would have to analyze the incoming samples, how many of LSBs are constantly zero.
Code:
cat /proc/asound/card*/stream0
TOPPING D30 at usb-0000:00:14.0-8, high speed : USB Audio
Playback:
Status: Stop
Interface 1
Altset 1
Format: S32_LE
Channels: 2
Endpoint: 1 OUT (ASYNC)
Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000
Data packet interval: 125 us
Interface 1
Altset 2
Format: S16_LE
Channels: 2
Interface 1
Altset 3
Format: SPECIAL
Channels: 2
Code:
Topping DX7s at usb-3f980000.usb-1.1.2, high speed : USB Audio
Playback:
Status: Stop
Interface 1
Altset 1
Format: S32_LE
Channels: 2
Rates: 44100, 48000, 88200, 96000, 176400, 192000, 352800, 384000, 705600, 7 68000
Interface 1
Altset 2
Format: S32_LE
Channels: 2
Interface 1
Altset 3
Format: SPECIAL
Channels: 2
I did some routing around and found I had Daphile set to play silence for hardware sync (something like that). My thought was that this would only apply for the start of playback, not between tracks. I changed that setting from .25 seconds back to 0 and that seemed to fix things (I also disabled flac and wav under the mp3 settings, not sure if that helped any. The one complaint I do have about Daphile is there isn't enough information about what all the "advanced" settings are for - I still have no idea what all the buffer settings are supposed to do)
On that upsampling front…
I have a Shanling M2s that I occasionally use as a DAC. I have it set to upsample everything to DSD64. I will get a slight click between tracks, not sure if there's anything to improve that?
The only reason I do upsample the Shanling is because it will click and pop like a dirty record if I use PCM. I'm pretty sure this is due to a hardware issue since the same problem occurs on my main laptop running Windows (Shanling has been able to replicate the problem but can't figure out why it happens), but has anybody else experienced these types of issues?
The M2s will also occasionally start outputting a single channel and will pop the heck out of my headphones when I play/pause/skip tracks. The only way to fix this is to physically unplug/replug the device. Again, probably a hardware issue, but anybody have any thoughts or suggestions - other than stop using it and buy a proper DAC (my other output device is a Fiio X3 mkI and it is mostly bug free)
Cheers
All Clear,
thanks PHofman
Hello
Is there a screen saver for Daphile that would work on the local user interface and could switch off the monitor or dim it.
Thanks.
thyristor44
Thanks.
thyristor44
is it possible to collaborate with this projekt and integreate it in daphile Pulseaudio Crossover Rack - multi-way crossover design & implementation with linux
plus to have ripping into mp3, ogg, opus and the wav formats - not only flac -
You can of course have a simple script that automatically converts the ripped files.
I've just been given a Teralink-X1 USB-SPDIF converter, but it seems it won't work with Daphile. The info I can find says it supports Windows (up to 7) or Mac. Is there a simple way to get it to work?
Check the daphile device output sampling is 96k or lessI've just been given a Teralink-X1 USB-SPDIF converter, but it seems it won't work with Daphile. The info I can find says it supports Windows (up to 7) or Mac. Is there a simple way to get it to work?
Well, I would if I knew how! 😀Check the daphile device output sampling is 96k or less
Settings -- Audio Devices --> Max sample rateWell, I would if I knew how!
I've checked that now. It's set at 480000. The only other setting available is 41000. The Teralink-X1 only handles 48 or 41kHz signals, so I presume it's a driver issue. Oh well, back to the Behringer UCA202, which is the only option at the moment. I was hoping to try my Meridian 263 DAC.Settings -- Audio Devices --> Max sample rate
Teralink X1 is based on CM108 TeraLink X1 . This chip is a regular USB audio class 1 device and has been supported in linux for over 10 years. What does "it seems it won't work" mean specifically?
- PC Based
- Daphile - Audiophile Music Server & Player OS
