Dampening cloth
The damping cloth has the max effect at those places in the box where the air velocity is max. That generally is when the standing wave modes of the box are excited, with the max air velocity AWAY from the box panels. The max velocity locations are mid between panels, 1/3 between panels, 1/4 between panels etc depending on the harmonics of the resonants. Higher harmonics have lower amplitude, so the bottom line is that max air velocity normally occurs in the middle of the box. Lining the box panels with damping cloth therefore has minimal effects.
Jan Didden
PS I assume you mean "damping" as in to suppress movement. "Dampening" means make damp, make wet.
