DAD Prime - My big loudspeaker toy :)
I'm not Renato but I have converted my Tannoys to 3ways.
The difference is that the mid-range has become a lot cleaner and more detailed since I removed everything below 250Hz from their duties.
The Tannoys woofer section originally tackled everything below 1.2k so I would expect the effect to be more pronounced if they'd crossed even higher.
Charles - I have a set of Wilson Audio Tiny Tot 3's that are in need of the Puppy's and looking to build the woofer section. Can you or have you a link where you were able to publish your build into a 3 way? I am particularly interested in the crossover's.
Thank you
jim
Sorry, I got no documentation of the build at all. Did it in a mates employers workshop after working hours.
Crossovers are modified BSS FDS360 using standard 24dB L-R cards.
The eq function of the original passive Tannoy ones is being provided by a parametric equalizer.
