i have got proceed dsd digital audio processor
but dsd dac card dosent work front L/R .
this unit use one dac card two pcm1702. one 1702 left other 1702 right channel.
1702 input signal type
DL = (data left )
CLK = (clock)
LE
other Pcm1702
DR = (data right)
CLK = (clock)
LE
my question
can i use just one dac (for example pcm1710 . Pcm1702 is mono Pcm1710 is stereo dac using)
1710 input signal type
DIN = (data L+R)
CLK = (clock)
LE
important part how can i use same to PCM 1710 signal type
other problem how can i converted two Pcm1702 (DL+DR) input signal same to one Pcm1710 input signal for using.
sorry i can't speak in english verywell for this excuseme
DL = (data left )
CLK = (clock)
LE
other Pcm1702
DR = (data right)
CLK = (clock)
LE
my question
DIN = (data L+R)
CLK = (clock)
LE
kaldirdimgell said:thanks to replies guys
I am sorry the problem is not clear to me. Could be due to poor English or lack of technical knowledge... No offence ment!. Please try to reformulate the core issue.
If i understand right your Proceed dac board with separate L/R dacs does not work and you intend rebuilding it using a stereo dac, correct?
Why not just repair what you have? Have you got a scope? Can you verify the L/R splitting is working and the dacs get the expected inputs? Are you sure the board gets correct input?
Building a new board can't increase the resale value by much.
awpagan said:
Probably not. The OP would be better advised to fix the original board as the PCM1710 is incompatible with the DF1700.
rfbrw
Well maybe not.
but i was referring to his posted schematic.
kaldirdimgell said:thankyou for replies. you can see the attached my problem
You cant join together DOL and DOR, I'm not familiar with DF1700, but I'm quite sure, that DF1700 outputs data simultaneously. You should to try repair your equipment. Or take digital data before DF1700.kaldirdimgell said:thanks for all
- Digital Source
- dac problem
