I would like to know if there are useful guides available on PCB design for DACs (probably something oriented towards medical grade devices)? How would I go about getting libraries for estimated stability and other parameters if I were to work using free tools like KiCAD, LTspice, qucs and gnu octave.
I have had formal education in certain branches of electronics if that helps and have also taken considerable time to learn designs online (few nice places like allaboutcircuits.com, and some earlier op-amp schematics and design choices). I am open minded about design choices, don't quite subscribe to sine sweep objectivism.
I started going through amb gamma 3, which is a diy dac. I am able to comprehend the design (data flow path, and components like clock circuits, switches etc) and I could also understand the analog circuit in their beta 22 amp but I couldn’t get to understand the PCB part or how the design process is carried out for the pcb and choices in the design. I am currently looking into PCB design for raspberry Pi compute (there are resources on the same) and have been able to learn a little with respect to digital pathways, but for random analog signal like music in not able to gather useful information.
I haven’t done anything like this before but I have tried spice tools with basic circuit simulations and fairly comfortable with MATLAB (have implemented few low pass filters in it) and certain stuff about design rule checks. I am trying to get used to KiCAD and am fairly decent at scripting.
I have fair (beginner level) understanding of available components for clocks, buffers, flip flops, switches etc (got by looking at teardowns of many amplifier designs and then exploring their design choices) but would again love to see more known good choices for each. Few parts that have currently got my attention are - si86xx series of isolators, el2001 buffer amplifier, quite a few opamps (analog devices ad8397, ti alm2402F), some transistors from vishay, sowter/Jensen transformers (if I were to make the output transformer coupled). Haven't thought a lot about attenuator for the dac yet since it is likely I'll let either xxhighend or the amplifier following it do that task. Will need to choose the right components as I explore making the design.
I want to try and build one based on ti 11001a (it’s a new unit) or any other r2r chip dac like ad1865. I believe it would be a little more complicated than delta Sigma due to the transition nature of r2r which could cause additional instability and ringing, but that’s the challenge I want to face and learn. And it would be NOS, with interpolation being handled by pc source (likely xxhighend+arc prediction) so atleast one complexity being taken away. Digital input interface would be custom as well (haven't confirmed but likely usb since I need to use xxhighend).
Of the existing diy dac designs, dddac1794 is something that has got me interested a lot (except the waveio board), because of its high bandwidth analog section. I also found some chips from audio gd for diy builds but couldn't find any schematics on the same.
I don't expect to get a masterpiece in first shot, rather want to really grow myself as an analog designer over time, and this is something I treat as a learning process.
I have no experience with the DAC chips you mention, but here are some very generic remarks about DAC PCB design:
A DAC multiplies its digital input signal with its voltage or current reference and the output signal gets phase modulated by jitter of the clock. When data-dependent signals end up on the reference or clock, the multiplication with the digital signal causes distortion products to be produced. Any other interference ending up on the reference or clock causes intermodulation products to be produced, except when the interference is at an exact multiple of the sample rate.
All in all, you have to ensure that the reference and the clock remain clean. That is, try to minimize crosstalk from the digital part to the reference and clock. As the digital signals have harmonics far into the megahertz range, you have to apply RF techniques like ground planes and minimized loop areas.
When the current that the DAC draws from the voltage reference is data-dependent, which it usually is to some extent, reference decoupling capacitors have to be placed right next to the DAC to minimize data-dependent voltage variations due to trace inductance.
DAC chip manufacturers usually write application notes that include PCB design recommendations, so it would be a good idea to read those.
Thank you very much. I will expore further on these topics. I donot have much rf background (other than basic Maxwell's laws and a beginner level knowledge in electromagnetic waves), any particular books/blogs you'd recommend? I came across a few articles and videos on ground plane design earlier but since I'm not familiar with it yet, I only studied the very basics (how the return current causes voltage fluctuations and something about type of metal wires for some kind of rf suppression).
Many datasheets give layout and decoupling recommendations for mixed-signal chips like ADCs and DACs, follow these as accurately as you can and keep digital and analog sections of the PCB separate. You need to ensure the analog ground isn't polluted with digital currents, and that star-grounding is used in the analog side to avoid loops that pick up interference. The datasheet performance figures are dependent on suitable layout and decoupling, and often on the reference voltage source quality (if the chip uses a reference).
Thank you very much. By keeping digital and analog sections separate, does it mean galvanic/optical isolation or something else more profound? Si86xx was recommended by few people (in another electronics server) for its speed while still having good isolation.
Also mostly all of those:
Technical Articles/Talks
This is a fantastic list. Thank you very much. Going through the PDFs now.
ESS has some advice on dac board design in the following document: http://www.esstech.com/index.php/download_file/view/69/267/
Also, one can download the ES9038PRO evaluation board design files, so one can study how they laid out the reference dac board.
https://ismosys.com/wp-content/uploads/2020/08/ES9038PRO-8CH-Ver-1.3.zip
Maybe some tips on how to use a scope for working on such pcbs ?
I'm a fan of OTT consultant writtings shown above as a basic enthusiast with limited understanding while the book is pricey for an enthusiast but surely one of the best invest in op situation.
Here also at Diya, good advices of a Member named Marce, cool guy, iirc his daily job is about HF pcb designing.
A really good intro to scope probing techniques: ABCs of Probes Primer | Tektronix ...probe grounding techniques are covered in a few pages near the end. IMHO, that's one of the big issues with probing PCBs at HF/RF.
Ground in PCB Layout - Separate or Not Separate? (with Rick Hartley) - YouTube
Already mentioned it in your other thread, but maybe others find it interesting as well. There is some other interesting videos on that channel, I mainly like to watch the 1-hour-ish talks Robert has with industry professionals.
Edit:
In the beginning another video is mentioned, I believe it is this one (from the Altium YT Channel - which you probably also know already): [LIVE] How to Achieve Proper Grounding - Rick Hartley - Expert Live Training (US) - YouTube
Edit:
Thanks for that.
ESS has some advice on dac board design in the following document: Page not found – ESS Technologies
Thank you very much. This is a very useful reference. I opened the design using the freeware version of DIPTrace. I am new to this, so far I have found that
1. To the left there is the USB input, its clocks and an isolator.
2. Below the USB inputs, there are Pins Named SIP 2x1 but I am not able to understand what it means. I think it is the unit sending data to the DAC but I couldn't figure out how to see the connections, or the drive logic.
3. To the Right end there is Power supply and ground contacts/pads.
4. At the centre I find the ESS dac and clocks, above and below I see pairs of 8 analog circuits one for each channel.
5. Lots of Resistors and Capacitors.
I would like to know if any of the above is wrong.
I am however unable to look at the wire connections in this model. I earlier tried opening Raspberry pi 4 compute module template PCB on KiCAD and I was able to see the wire connections clearly between the compute module and all its interfaces (and I could turn the visibility off if needed). Is there a way to get similar view using DipTrace?
The ES9038PRO evaluation board is a 4-layer PCB. The free version of DipTrace only supports 2-layers, not sure if it will let you look at more than that or not. KiCad might be a better free one to try, its been improving a lot over time. With the right software you should be able to follow (or even highlight) where all the traces go as they pass through vias to difference layers.
You can view more than 2 layer documents, but you cant edit. also it is specifically 2 signal layers in the free license IIRC, so you can – I think – design with 2 signal layers and 2 ground planes. Dont quote me on that, but someone could try. I have the 6 signal layer license
Thanks for the help, I was able to understand the positioning of components. But I guess I wouldn't be able to infer further about the layout of this ESS reference without a license.
Are there any other layouts that could be opened through free software (preferrably Kichad)? For now I am looking into raspberry Pi 4 compute module reference PCB to understand how digital interfaces are placed.
- Digital Line Level
- DAC PCB design guidelines help!
