I'm using RS423'ed I2S as well, but I only needed one hole for a 9 pin d-type socket.
I'm sure SPDIF can be implemented well, but it is a further coding conversion method that can be made redundant, so why not as there is a risk it can impact the signal quality?
It also makes my DAC simpler, as I don't have to worry about implementing an SPDIF receiver.
tubee said:I2S can also easily fed in/out with a simple one-hole (mini) DIN socket.
No
tubee said:shielding?
Transmission lines.
Each are 50-Ohm so you need 50-Ohm chassis parts and connectors. There is where Audio Alchemy failed.
