Here the final schematic
Got my LL 1684 but I am not sure I understand ground connections on this schematic. 😕
Where is the problem ?
Balanced output need center tap to ground
Un-balanced output need lateral tap to ground
So there is a switch ?
Hello Andrea,Here the 58a standby for you.
I tried this version , but the display remain black ( no display) and remote
control has no effect ?
I came back to the precedent version and all is ok.
Br
Jacky
Hello Andrea,
Br
Jacky
This version is not for all, this is the standby version to use only if there is a separated transformer for controller.
Sorry Andrea , i should to pay attention !
Br
Jacky
How will a 22 uf Bipolar Capacitor ( like nichicon muse ) work between gnd in and gnd out. High frequences ( noise) will not pass the Capacitor.
Did not work at all almost no signal. 🙄
well big mistake . My power amps was in se mode at input. But the sound . I really do not like it. 🙁 Have to change the 2x15 uf. RFX Mundorf and 2x 6,8 nf. Silver Mica to Black Gate.
I am going to buy the chip quik de solder kit SMD1 or SMD1NL to help with some of the modifications/fixes.
Should I buy the standard or the lead-free version of the kit?
Chip quik uses a low melt solder which combines with the solder on the chip and reduces its melting point. So I need to know whether the DAC board has been soldered lead-free or not. Can anyone help?
I use LL 1684 for output off my dac now , but I do not like the sound at all. Distortion and very hard midrange and treble. Maybee I should change the Capacitors for that circuit ? I use 2x 15 Uf Mundorf RXF and 2 x 6,8 nf Silver Mica for each channel.
Hi Quanghao,
Two questions:
1) What is the function of the pink wire that connects R44 to R3 ( post 2073 )? In my DAC the two resistors are not mounted.
2) With the DAC/1684 you have tried to keep floating the two secondary of the trasformer and connect to chassis pin 1 of the XLR ( balanced output )?
The DAC with opamp sound wonderful.
Two questions:
Hi Quanghao / Andrea,
Are three any unused input / output pins on the PIC that I can use? I would like to implement trigger in/out functions. Would need to program the PIC obviously and I guess build some sort of daughter board to piggy back onto the PIC socket. I can then completely replace my preamp!
- More Vendors...
- Quanghao Audio Design
- DAC-END R (ES9018) full assembled board
