DAC build TDA1541A/SAA7220P/B *will take som time*
Got some work done on the DAC today, not much though.
OMG...an oscilloscope too ?
Your like an engineer already !!
The red LED's on your TPR's.......are they 3mm and will 1.5v ones be OK ?
I've also found 1.8 - 2.4 volts @ 20 ma.
Which ones do I need ?
Very generous that friend of mine...to say the least.
Engineers know how to use the oscilloscope 😉 I don't, yet.
3mm is fine, but 1,5V is not enough, the diodes act as the voltage reference(1,85+1,85+1,25=4,95Vdc) in this circuit. You could replace the two in series with a trimpot and tune voltage that way.
The ones I used(sorry for the Swedish on that site)
With these I get 4,95Vdc w/out load and 4,73Vdc w load.
Dac looks almost finished !!
How much to do now ?
Caps in the CD Player yet ?
Not enough time - I know this problem😱
Not much left to do on the DAC, but critical part like TCXO and transformers are still to be ordered.
Haven't gotten around to put the caps in the cd-player yet.
I have so many projects to build now that it's insane.
100W/4ohm digital amp
3 tube preamps.
One remote controlled preamp w display and input selector
My B1 preamp.
My 3 cd-players
My Dac.
My tube amp I get on friday.
AND learn how to use an oscilloscope. Old but very high quality.
Build is not abandoned, waiting for some parts and to afford to order other parts.
Also I've been busy with this tube amp
I found the fault, a resistor that was broken(a 51R resistor responsible for poweringen one channel of the amp). Also I'll put a second on-off switch (on B+) so that I can switch on heaters, and then 20-30sec later switch on B+.
A manual softstart of sorts.
I've ordered a custom transformer for the DAC.
It's a toroid 60VA 230V primary.
Secondaries:
0-9Vac 1A
0-15Vac 1A
16-0-16Vac 1A
A picture of a friends transformer from the same company that's making mine.
This way I get away with using one transformer and it was actually the cheapest option.
This leaves room for a copper "wall" between transformer and DAC (and later tube output).
Could someone please give me the search words for ebay or link me to a place where I can get a dip socket with the right dimensions that can be modified to be a TCXO-socket(cut to size and remove excess pins I guess). I want this in part to be able to swap/upgrade TCXO and also to change them in time as they age.
I have 4pcs OPA604 and 2pcs NE5534.
I'm thinking of putting the entire thing together when I get the transformer and TCXO using OPA604 for I/V and Buffer/Filtering.
Listen to the dac this way for a while before putting in the ECC86 outputstage.
Will this do as a TCXO-socket? Either breaking of 4 pins or two rows and removing unused pins(this approach would make for a more stable socket).
