Having just powered up my finished (but uncased) DACEND 2, I notice that L19 (LED connected to pin 28 of the CS8414) is on permanently, even with no input signal. Should this be the case? All six shunt PS's appear to be OK (ie. easily adjusted to precisely 5V). Also, no output signal is detectable when a CD transport is connected. Could this indicate a faulty CS8414?
Any thoughts/comments would be appreciated.
Thanks.
Thanks.
Thanks.
yes, CCS8414 have problem!
And you connect jum 1 to 2, in the board DAC!
im interest of dac ash.... did you have stock of pcb mr quanghao??
please give me total cost 1set pcb dac ash n payment method..
i send u email from ermac_1982@yahoo.com
thank you
Hi!
The price PCB ( PCb up dat 2011)
PCB DAC = 40$
PCB IV stage 40$
Shipping by airmail= 10
Please see this link:
http://www.diyaudio.com/forums/quan...287-dac-end-best-dac-ad1865-updat-2011-a.html
Hi Quangao!
Excuseme if i disturb you too.
I have any question.
Can i use semiconductor diode 1N5819 or 1N5842 for 2A 800V? Excuseme but i dont' understand.
Can i use the four diode for anodic? Or only two without D9 and D11?
In this link i read like this (308 and 309):
http://www.diyaudio.com/forums/quanghao-audio-design/171999-dac-ash-dac-end-2-up-date-31.html
The latest question: is it right the 2SK170 SR?
The dac that i would built is the second "DAC END" not the last of 2011.
Thank you!
Regards.
Antonio.
Thank you!
Regards.
Antonio.
I'm going to pick up on this project again after a busy year. Haven't manage to get it working yet.
My first question. For the DAC board, all my LED's are flashing and not solid but I'm getting 5v for all of them. Is that normal?
Thanks.
Thanks.
Thanks.
Hi Thats not right mine stay on solid all the time cheers john
Thanks for your advice. I've replaced the CS8414 & the LED is now on at power up & when there is no SPDIF signal (ie. DAC is idle). When I select PLAY on the CD player (transport), the LED goes out, but there is no output (audio signal) to I/V stage.
I have triple checked placement of all components on the board. Voltages at IC pins are what they should be & the six SS regulators are running at the same temp (barely warm). CS8414, 74HC04 & AD1865NK are good.
Any ideas where I may be going wrong?
Apologies if this isn't the right place to post this query; this thread has gone very quiet..........
Hello!
I have builded DAC END 2...it's fantastic!
A large soundstage and a natural timbre! Sounds very very good!
Thank you Qhanghao an Andrea!!!
Unfortunately i don't succeed to put the photos of dac! Can you help me?
I have question: I have used the 6DJ8 ...what is the output voltage and the impedence?
Thank you!
Antonio.
Thank you!
Antonio.
Hello!
Thank you!
Antonio.
Please see the page 1, post 5
http://www.diyaudio.com/forums/quanghao-audio-design/171999-dac-ash-dac-end-2-up-date.html
Pcb Of dac-ash-dac-end-2
Where do I find Pcb Diagram and Bom Of dac-ash-dac-end-2.
Viki
Viki
Hello Qhanghao!!
Thank you for information! Excuseme, but i don't understand...page 1, post 5 for impedence and voltage output? Please can you help me? This data are important for me, because i'd like interface correctly the dac with amplifier (1 volt 15 kohm input).
Thank you!
Antonio.
Hello Qhanghao!!
Thank you!
Antonio.
what tube do you use??
5687 pcb
Hallo Quanghao,
What kind of inductor L 120 uH Do you suggest
Do you have I/V pcb with 5687 tubes?
Many thanks,
Hallo Quanghao,
Many thanks,
Hallo Quanghao,
Many thanks,
yes! if you not have it, you can not use!
Tee PCB iv, i have it!
thanks
- More Vendors...
- Quanghao Audio Design
- DAC-ASH (dac-end 2 up date)
