DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
Here is something interesting. Peak is around 33KHz. LF roll off is primarily determined by the inductance of the transformer.
It should simply be a matter of removing the vacuume circuitry and replacing it with sand.
How's this for an output stage for the ak4396?
Ray's Audio Page - Discrete Output Stage
If I am not wrong I think that is the HDAM discrete circuit, though in this case with the CFP mod.
I think it could be tried on the AK4396, probably eliminating the 100uF capacitor, which I think it's a must in the Marantz they made it for.
Another problem is the input filter, which involves inductors.
On the picture of the PCB in post #95 on page 10 of this thread there is a round capacitor marked "1uf" next to cap 28. Which one is this on the BOM?
It should be marked C37, and is a 1 uF cap.
It doesn't appear on the "upgrade BOM" because Dario didn't see a need to replace it -- thus no change from the stock cap provided with the 2496-mini-DAC kit.
It is listed in Dario's "full BOM" as a 1 uF capacitor, 50V, any manufacturer, standard elco capacitor. My kit came with a dinky teapo 10/00 (?) cap, rated for 105 degrees C. Most of the photos posted on this thread show a larger cap, but it's up to you.
I hope that helps !
AH0JFFhBSgscEuIMXOiLDqMGeFpxgcIqig6Gn9aEMDFJEqBEPTa5EjRQEYRDCiIQWNlml6xIYQwJnPJCgY8ALgaI0BCg1xw4d3ydukVlEa8AYBCgsREgA6pRfJysIvOEw5c3WzQdyEXID4NYmUBomUFBzZUCAhAUOAALQJkVbnY0wqRnEBEDBs4ASCCgFJMilWoUIiUHhi0AZuoMSKBiAok0nB5l8SKqT5cYAxwIAMDCAwpVQj74wlUlxRggqZYEqmVpRA4sJQSyoWEliaMflJCAGvJA155LA8UY4UFr1qsFHZTkOQKJ4QlEF0wFkfGniZ1QDAdiuLHBUycLDAMCADs=
