I don't think so... MC7812 has 10 uV output noise vs 76 uV of the KA7812.
Thanks for explaining that.
I was wondering what the difference was. I know what to look for now.
okay i got it working 🙂 detailed but not so musical
caps out-5670 cathode follower-tripath...sounding a bit thin but should improve greatly with burn in.
i've got noise on output...much like unfiltered SMPS..but it cant be it's battery powered..could it be ultrasonic noise because of direct out mod?
thanks.
thanks.
okay i got it working detailed but not so musical
That's how i would describe mine at first switch on.
I've had it on continuous for four days and it's now quite laid back and the bass seems to be getting stronger.
I have had no problems with taking the output straight from the DAC into a tube stage. Not much help i'm afraid.
Can you try something else through the cathode follower?
yeah and im using jan 5670w which is very thin but detailed hahah
and it works really well with other sources.
i'll probably try 12au7 anode follower with a bit of gain before cathode follower-to get it more smooth and dynamic..but thats not the main problem, i just noticed noise issue and i cant believe it, its grounded properly,yet it's almost unlistenable 🙁
but i dont get it...could regulators be so noisy? highly unlikely...its battery powered so PSU isnt a issue here...
also4.3uF ASC cap works really well with this dac(details impress the most, and i havent even bypassed it yet with PIO or MKT1837)
this gets me thinking to get an passive eq/tone control 🙁
so, once again music is less interesting and unforgiving of poor mastering.
p,s. dac seems to shine with 96KHZ upsampling - tried it with foobar and bass increased ridiculously and so did highs 🙂
thanks.
Maybe you're lintening on noise floor. But it shouldn't disturb that much. Listening at 0db and using a physical attenuator may help if you have not any idea.
It happens when the LPF is bypassed...
You should implement the same filter with valves... 😉
So. Are you suggesting that the output should be taken from after the filter, rather than direct from the DAC ?
No, I'm suggesting that if someone want to use discretes or valves instead of datasheet's LPF, he should also implement the same filter using them.
Hot Running
On my DAC kit .. a non-assembled version.. it says
" MINI2496: Just use a dual-AC13-15V power supply and a set of AC9-15V single power supply. Can also short the PCB on the back of the two pads, so a dual-AC13-15V power supply can work. Reduces power requirements. Transformer can be greater than 10 watts." (This is an exact copy of the translated material.
I am wondering if there is any relationship between overheating and dropping the 9V input in favor of the dual AC13-15V? I can see the simplicity gained but perhaps the voltage drop is causing😕 the overheating. Can anyone comment on their experiences with both forms of power connection?
Also, the wattage rating for the transformers supplied for the assembled kits is 30VA. This seems pretty safe considering that 10VA or more is suggested.
George
George
I have got the pads shorted and just using one transformer.
Yes it gets quite warm but not overheating in my opinion.
There again i'm not using an op-amp, so that must be less strain on everything.
okay so, my conclusion is this dac is a stellar performer, such focus, power and speed with incredible details has to be heard....for 40$ 😀
okay so i've got single 12V battery, mix of oscons(for supply) and tantalums(filter especially),one FC,siemens(epcos) sikorel, silmic for analog supplies and direct cap out mode and currently developing pcb for crc -lm317-c-7812-C(all bypassed with ceramic or mkt/mkp) with a total of 10 000uF directly to lm1117s...lm317 has mighty PSRR for 50hz and upto khz and 7812 deals better with higher harmonics 🙂
Good stuff.
How much difference did the mods make?
Mine isn't theoretically run in yet, and unmodded.
About half way perhaps.
I find it extremely laid back and yet detailed at the same time.
Very different to the Lampucera.
My unmodded AK4396 version has an offset of 2mv on left output (0mv on right). Did your boards have DC offset too ?
Thx,
Thx,
Hello,
My unmodded DAC with AK4396 outputs 1,32 mV on the right channel and 7,23 mV on the left channel in idle mode. Is that a big problem? What can I do about it?
Thanks,
Jeff
Thanks,
Jeff
Component numbering
Clave, just wondering where the component numbers in your BOM come from?
My board (i got the kit) doesn't have numbers (C22, C23 etc...). I can probably figure things out but it's going to be much easier matching up your numbers with components on the board.
Did anyone else get the kit from zoe_tsang without any screw terminals supplied??
check out post #95 page 9
The most updated version is in this post.
In the starting post of the thread you'll find the schematic with same numbering.
- Digital Line Level
- DAC 2496 (AK4393) DAC KIT With CS8416+AK4393+5532
