Hello, (sorry, longish post)
About two months ago my old Cyrus Power Amplifier broke dowm.
I was using it in a bi-amped system (with a Cyrus IIIi) driving four Cyrus 780 (made by Mission circa 1990, and not to be
confused with the Mission 780).
The Power Amp was driving the tweeters.
Opening it made me realize that repair wasn't an option. The PCB was badly burnt at one if its corners.
I contacted Cyrus in the UK for some advice. When I mentioned that the PCB was burnt, they basically could only offer me
an expensive upgrade-service.
So for a temporary solution I revertet back to a basic setup with only the Cyrus IIIi driving the speakers.
It sounded reasonably good. The tweeters didn't appear to have been damaged.
However, I recently got hold of a newer power amp, the Linkpower, to replace the old power amp.
The sound quality is not what it used to be. The treble is quite sharp/harsh and is not so nice to listen to.
The sound used to be considerably more "soft".
The problem is especially nocicable in the vocals of a song. The S's sound horribly poor/bad, and is more like three S's rather than one....
....especially if you're playing rather loudly..... ;-)
At the moment I have the Linkpower connected to the woofers (LF), and the IIIi connected to the tweeters (HF).
I have tried connecting the other way around, but that didn't make any audiable difference.
I have checked the components at the HF-input, and they seem to be OK.
Measuring the resistance of the tweeters in two of the speakers, gives a value of 6.2 to 6.7 ohms.
Since I couldn't find my own user manual I tried finding info about the speakers on the web.
Weirdly enough I haven't been able to find much, and neither Cyrus or Mission have any specs/manuals for it online.
No specs/info is located at the back either. From memory this line of speakers have an impedance if 6 ohms. I found someone
selling a pair of 780s at eBay, which confirmed this.
The Mission 760 is the "little-brother" in the series, and it has an impedance of 6 ohms.
Now. If the impedance is 6 ohms, the tweeters resistance shouldn't be any higher than approx. 5 ohms. Correct?
I've played around with the thought of reversing the polarity of the tweeters.
Either directly at the tweeter, or at the amplifier. Most likely that will make it sound even worse, or?
Have any of you any clues where to get hold of these tweeters?
The part.no is R761-HFU-D19. It's used in several other Mission speakers. Like the Mission 761 for example.
I have contacted both Mission and Cyrus, and only gotten a reply from Mission as of yet.
Strangely, Mission suggests replacing the bass driver (woofer). This sounds very weird to me, or are they on to something?
I've also found this: http://www.gvibes.com/parts/oldpartsinventory.txt
I contacted them as well, but have yet to hear from them.
Any help/tips/suggestions would be greatly appreciated.
Daniel
Daniel
OK, Isn't there an equivalent Mission version of the same size?
Wouldn't a Mission 780 or 780se be the same as a Cyrus 780 of the same period? I know it is confusing because Mission use 780 for different speakers at different times.
Mission and Cyrus were the same company in those days and Mission usually share the same components throughout an entire range.
These two items are the same size:
Cyrus 780: http://cgi.ebay.co.uk/Mission-Cyrus...4QQihZ018QQcategoryZ14991QQrdZ1QQcmdZViewItem
Mission 780se: http://cgi.ebay.co.uk/Mission-780se...2QQihZ010QQcategoryZ14991QQrdZ1QQcmdZViewItem
It's probably too expensive to buy the whole speaker just for the tweeters. I don't know.
How does the tweeter sound with the 3i powering the woofer at the same time?
The 3i (I think) was made because the first Cyrus 3 sounded too harsh and brittle. That's what I read somewhere anyway!
I've had a similar problem with sibilance (sssss tttttt). It drove me crazy and I tried everything to fix it. Now, after a long time, I realise that I just need some more bass to balance the sound.
Could this be why Mission recommend a new woofer? Or is the crossover point very high on your speakers?
A lot of recent Mission speakers use Vifa drivers. Could you find a modern replacement? Maybe speak to Vifa and ask for a recommendation? Or someone around here might know. I am just guessing, sorry.
I will think again when I am more awake!
Anybody else got any idea?
Martin 🙂
Martin 🙂
Sonusthree said:OK, Isn't there an equivalent Mission version of the same size?
Interesting. I thought the Mission 780 looked like this:
http://oldsite.mission-hifi.com/product/78/loudspeaker_780.htm
The strange thing is that you can't find a user manual or any info about either the Cyrus or Mission 780 (old version), on either mission.co.uk or the old site.....
Sonusthree said:How does the tweeter sound with the 3i powering the woofer at the same time?
Do you mean when only using the 3i and skipping the bi-amping?
Sonusthree said:I've had a similar problem with sibilance (sssss tttttt). It drove me crazy and I tried everything to fix it. Now, after a long time, I realise that I just need some more bass to balance the sound.
It could be, but I don't get why the bass driver would be damaged after a failure of the amp I had driving the tweeters? Very unlogical.
Crossover-point? I have no idea since I can't find any specs for this speaker (other than that the impedance i 6 ohms)....
Sonusthree said:A lot of recent Mission speakers use Vifa drivers. Could you find a modern replacement? Maybe speak to Vifa and ask for a recommendation? Or someone around here might know. I am just guessing, sorry.
Don't be sorry. I'm thankful for any help I can get.
Contacting Vifa is not a bad idea....
I've done some research today and here what I've come up with....
Tweeter:
Mission part.no. R761-HFU-D19.
The tweeter is a Vifa D19.
Most likely D19TD-05-08. Impedance 8 ohms, which would make my value of 6.2 to 6.7 ohms correct.
Problem is, there are several similar versions of this one. All with different impedances...
Woofer:
Mission part.no. R60 80-LFU-C13.
The woofers are Vifa C13.
It could be C13WG-08-08. Impedance 8 ohms.
That would make Mission's advice correct, since my woofers measure approx 3 ohms resistance (should be 5.5 ohms).
Different versions of this are also available:
C13WG-19-08: Z = 8 ohms
C13WG-08-04: Z = 4 ohms
C13WG-08-06: Z= 6 ohms
C13WH-09-08: Z = 8 ohms
C13MG-07-08: Z = 8 ohms
C13MG-08
C13MG-09-08: Z = 8 ohms
Tweeter:
Woofer:
C13MG-08
quaddo1 said:Tweeter:
Like this? He posts worldwide too!
http://cgi.ebay.co.uk/Pair-of-Vifa-...yZ112517QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Yes, that looks like the same as the ones I have.....thx!
Although, I'm not totally convinced that the tweeters are at fault any longer....it could be worth a try though.
I've been thinking....
Is it common practice to have different impedances of the drive units in a speaker?
If so then it's not impossible that the tweeters have an impedance of 8 ohms (approx. 6.5 ohms DC) and the woofers have an impedance of 4 ohms (approx. 3.5 ohms DC).
If the DC values are correct, then they aren't much use in helping with sorting out my treble problem.
Anyone agree?
Anyone agree?
I'm VERY confused.
You like the speakers with the first amp.
It broke.
It was OK with the second amp.
You don't like it with the third amplifier? So you think your tweeters are damaged and you want to replace them?
Now you think that you simply have too much treble?
Maybe it is logical to blame your new amp?
Have you tried changing the speakers position to get more bass? Try placing in a corner or against a wall and see what happens.
Try an EQ to give you more bass/less treble and maybe you will know what you are looking for. Even Windows media player will be OK for initial testing.
Sometimes reversing tweeter polarity can help with problems at the crossover frequency.
IMPORTANT: Are your woofers wired correctly. If one is out of phase then you will experience a lack of bass and, therefore, more prominent treble.
If you want to reduce the treble then you could try an L-pad attenuator. This reduces the level without affecting the crossover frequency too much.
It broke.
Sonusthree said:I'm VERY confused.
It broke.
I couldn't see any other way myself. Maybe we're both dumb 😕
I don't think either of you are dumb.
It probably me who can't explain this well enough....
Sure, it could be the "new amp" (Linkpower) that's causing the problem, but to me it's more likely that something got damaged when the old power amp broke.
It wasn't all that obvious when I only had the IIIi-amp to drive the speakers.
Upon getting the Linkpower and re-connecting everything to a bi-amp setting, each driver gets more power (or watts if you will), and it's then the problem rears it's ugly head....
Sorry, but I can't really explain it any better at the moment....
Each driver should be getting exactly the same power as with just the second amp, if you use the volume controls to set the tonal balance the same.
Either you have the volume up too much on the tweeter amp or your new amp is just harsh.
I think it is worth trying my EQ suggestions.
This will show you if it is purely a matter of tonal balance.
Eliminate one possibility and then move to the next .......
This may be of interest to you. The exterior is slightly damaged so might be cheap. Also, maybe the seller would send you the drivers and crossover only to save postal charges.
Anyway, just another option for you.
http://cgi.ebay.co.uk/MISSION-CYRUS...8QQihZ017QQcategoryZ14991QQrdZ1QQcmdZViewItem
Martin. 🙂
Martin. 🙂
- Cyrus 780 - Tweeter/Treble issue
