Current feedback application of LM1875
Why? 1875... Built as per the Data sheet! is a decent amp.
Not world beating certainly, but better than most commercial efforts of comparable power output .
And especially Why ? if 'Not into electronics' 😉
Could try for a composite build much like the ones developed for the Lm 3886 .
That has proven to give advantage.
Reactions: TNT
Can you recommend a composite build thread/instruction?
You can look at this one:
https://www.diyaudio.com/community/...-composite-amplifiers-based-on-lm1875.382575/
Years ago I put a lot of efforts to build Howland current pump amp using LM1875. Finally I got stable and nicely sounding circuit but far, far away from the sound of the composite amp describe in the thread above. If you have not very good speakers (woofers) a current drive can help but apart from that I couldn't find anything comparable to the sound of the composite.
LM3875 and LM3886 are hard to find, eventhough they are better than LM1875.
But LM1875 there are plenty of to buy.
