We want to implement 100V Audio Line in one of my project.The path is like this
Audio CODEC or Microphone Audio --->Preamplifier---->Audio Power Amplifier --->Step up transformer-->Distribution network-->Step Down Transformer(which is at loudspeakers) --->Loud Speakers (Each- 6W RMS,8Ω).
Maximum No of speakers : 8 Nos.
Impedance of spekers:8Ω
Maximum Wattage of each Speaker: 6W,RMS.
Power Amplifier wattage - 6W,RMS x 8 -->48W RMS.
We selected LM4780 as a power amplifier and using single output channel of 60W with DC Supply of ±35V Output at 8Ω load impedance.
We did the calculations for the step-up transformer and we ordered.I need Power supply specifications for generation of ±35V DC for LM4780.Supply Current was only given as spec in LM4780 datasheet.
Shall I need to take the loudspeakers,step-up transformers/Step-down current calculations into consideration or not?
Please give calculation regarding Output Current for the Power supply required?
Suneetha.V
Suneetha.V
This thread is in the wrong forum (this is Forum problems) - can a mod please move it?
To your question: since the load your amp will see is 8 ohms, you can size your transformer assuming you want +/- 35V which will give about 32V peak at the load which is 4A peak, or 2.8A RMS / 22.5V RMS in 8 ohms which is about 65 W per channel.
A 200 to 300 VA transformer for stereo would be fine, you'need about 24VAC.
Jan
Jan
