Which is it?
"The MC-cartridge is connected between +IN and -IN with 100 Ohm resistors to ground from the inputs. So the dartridge leads are totally floating with respect to ground."
100 ohms to each leg could hardly be called floating. I do think a fully differential input for phono is well the noise penalty. The extra noise is usually below the AC line harmonics that wind up mixed with the signal in a single ended input. Jocko and I have both built (different designs) phono preamps with differential inputs using the 2SK147s in the front end and were very happy with the results. Getting the grounding right on a tonearm and turntable can be a real pain. Electrical noise from the motor very often gets in the signal from the cartridge as well. It is a mystery why the phono input, the most affected by common mode noise, is so seldom done as a balanced input.
