CT Sounds AT900-1D
Changed power mosfets and output mosfets.
Outputs are 6 IRF640N and 6 IRF9640.
Amp pulls plenty current. IRF9640 gets very hot. With current limiting resistor amp pulls 3amp and giving very clean output.
Drive something of about 50Hz into it and look at the output of the TL072 and the LM211. The output of the TL072 should be a fairly clean 50Hz sine wave. The output of the LM211 should be clean and square on top and bottom. With an LCD display on the scope, I'm not sure if it's a real problem or simply dithering.
