Hi everyone!
I'm new to this thread and would therefore like to introduce myself: I'm a university student from Switzerland with a great interest in audio electronics, etc. I've built a preamplifier with integrated variable subwoofer crossover, a subwoofer amp and the (sealed) subwoofer itself so far. My Intention was to make up for the lack of low bass of my Tannoy Reveal studio monitors (I'm a music producer, too) and go for a sealed monitoring system. Now I got really interested in fullrange drivers. I've already ordered the FR125S from Germany and probably will put them into the standard bass reflex enclosure. This way I could seal them if desired and cross them over at 80 Hz to my sealed subwoofer. Now my question is: How linear are the drivers? My Tannoys are very linear and come close to the Mackie HR824 except for bass reponse. Has anyone made measurements of the frequency response of the bass reflex design?
They are pretty flat (+/-3db) to 20kHz. The only anomolies I've seen is a slight dip around 2kHz and a slight peak around 7kHz but well within tolerance.
Landroval said:Hi madscience. May I ask where from Germany did you order the FR125S's?
You can get them here:
http://www.boxen-baustelle.de/
Max
That's where I ordered mine from. However, it seems like I got the last pair of FR125s, a demo pair. I guess I had luck...Looking forward to getting them in a week or so.
I just ordered a pair of FR125's from Creative Sound. Has anyone tried them on an open baffle?
I was thinking of using the FR15S on an OB above 250 Hz, crossed over to a pair of WR125ST's, with dual subs below. The WR125ST's would be used in a sealed box, with either both firing forward, or one forward and one back (push-pull). So I guess you could say it would be semi-dipole or full dipole.
OTOH I don't know if I will like dipoles, so the backup plan is a totally enclosed, forward firing system.
audiobomber said:The WR125ST's would be used in a sealed box, with either both firing forward, or one forward and one back (push-pull). So I guess you could say it would be semi-dipole or full dipole.
What actually is the point of dipole in a box with two drivers (push-pull)?
Landroval said:What actually is the point of dipole in a box with two drivers (push-pull)?
I don't really know Landroval, I'm making this up as I go along. Comments are more than welcome. 🙂
I thought it might give a more coherent blend with the OB FR125S, if the frequencies covered by the WR125ST's (70 to 250 Hz) were also dipole. I'd need a huge baffle and bigger drivers if I wanted to go OB from 70-250, neither of which I want, so I need a box. Maybe it would be better just to stay with front-firing from 70-250?
Dipole is a dipole whether it's OB or push-pull-box. You'll still need the 5 foot wide baffle to go to 70Hz.audiobomber said:I thought it might give a more coherent blend with the OB FR125S, if the frequencies covered by the WR125ST's (70 to 250 Hz) were also dipole. I'd need a huge baffle and bigger drivers if I wanted to go OB from 70-250, neither of which I want, so I need a box.
A bipole box would be totally different.
Landroval said:Dipole is a dipole whether it's OB or push-pull-box. You'll still need the 5 foot wide baffle to go to 70Hz.
Oops, of course, you're right. I wasn't thinking. 😱
I don't think a bipole would work with an OB on top? I imagine there would be some major nulls FR aberrations.
audiobomber said:Has anyone tried them on an open baffle?
I hope to have a set of FR125s on my plexi open baffles by the WE.
dave
Depends... we did a fostex push-push bipole XOed to a dipole Heil ribbon. They are decent.
dave
dave
Terrific. If you wouldn't mind, I'd love to hear the details and results.
dave
Geez Dave, I'm going for KILLER, not just decent! 😀
I know you're at least as sensitive to coherence as me, if not more so. What do you think of mixing radiation patterns like this (semi-dipole, semi-bipole etc)? Does it work, i.e. is it still coherent?
audiobomber said:If you wouldn't mind, I'd love to hear the details and results.
We really liked them when we made them... but after living with the midrange coherency of the likes of the FR125 & FE108ES ....
Some pictures of the Heils can be seen in my Audio Vendor's Bazaar thread
http://www.diyaudio.com/forums/showthread.php?postid=453238#post453238
the original AMTs were (sorta) bipole (with a PR on the back). Below baffle step all boxes tend towards omnipoles.
dave
planet10 said:We really liked them when we made them... but after living with the midrange coherency of the likes of the FR125 & FE108ES ....
I have pure full-range coherence in the upstairs system (RAW-1F's fronted by some pretty nice electronics). What I'm trying for in my main room is nearly full-range coherence, but with the power of a multi-way active system.
planet10 said:Below baffle step all boxes tend towards omnipoles
Good point!
hello all,
i have a quick questione regarding the fr125s in the mini-onken: what do you do to compensate the baffelstep that begins at 600 hz?
thank you
lilmik
thank you
lilmik
LilMik said:i have a quick questione regarding the fr125s in the mini-onken: what do you do to compensate the baffelstep that begins at 600 hz?
Martin has some good tools for figuring out a BSC compensation circuit. I haven't played with one for the miniOs yet -- my general experience so far being that most of the time i don't like what happens with the circuit in place (and a predilication to bipoles). I still keep hauling out the Ls & Cs & Rs thou and play ...
dave
dave
It's really not as simple as just BSC. 😀
hi lilmik,
your flag suggests you read german right?
if so there's a thread is a gernam forum about 13L BR with the fr125s - they are also dealing with filters for baffle step and peak corrections.
http://www.hifi-forum.de/index.php?action=browseT&forum_id=104&thread=5882
for the english speakers there's something simular here, less detailed though:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=70255&pagenumber=5
best, lc
best, lc
I got to hear the Raw Acoustic CSS Speakers at CES in the Adire Audio room, they were wonderful. They were in a small ported box.
I was just wondering what your thoughts would be in putting the FR125S in an enclosure like this: http://home.indy.net/~gregdunn/dynaco/components/speakers/aperiodic.jpg
The first chamber where the speaker is mounted is separated by an aperiodic vent that vents into the second larger chamber. This way, the bass output from the aperiodic vent will not cancel the bass output of the driver as occurs in a single chamber aperiodic enclosure.
- Full Range
- CSS FR125S ... production units playing now...
