CS 800 Repair (with pics!)
The triac in question is a large TO3 type riveted to the bottom floor of the amp. It is a type Q4025 or Q4040 or similar. The power switch merely turns the triac on and off, the triac controls AC current through the power transformer primary. Triac shorts and leaves the amp always on.
Peavey CS 800 "C" Driver Board Layout
I've been working in the industrial electrical controls field for many years and haven't had a lot of experience fixing electronics down to component level.
My CS 800 amp developed a few problems and I'm close to having it back in full operation.
I wanted to share a picture of the component layout for the driver board I put together for myself. It makes finding the components much faster for the novice.
I hope someone else finds it useful.
Good Luck with all repairs!
Mike
Reactions: STOXX
hello, how or where can i get a wiring diagram for the inside the amp? some of the wire has been moved from a friend who thought he can fix it. it just needed the fuse cap to be replaced, but then he forgot were the wires go? I need a picture of of the wiring diagram
necesito ver las conexiones de los alambres del peavey cs 800 americano la version que es americano no china por que cambian un poco las configuraciones avisame si alguien esta interesado en ayudarme para mandarle las fotos necesito ver como restauro este poderoso amplificador
^ :cop: Translation.
I need to see the wire connections of the American Peavey CS 800, the version that is American, not Chinese, because the configurations change a bit, let me know if someone is interested in helping me to send them the photos, I need to see how I restore this powerful amplifier
Este es un foro en Ingles
