It's a long shot but you could try the manufacturer.
Ebay has replacement blocks but you have to be careful about the reach into the amp and the orientation of the screw and terminals (where they solder into the board) as well as the pin configuration.
Are yours missing or beyond saving?
I will find out what type wire he is using. I just had repaired another amp (Power Acoustik) for this guy where the ground terminal melted out of the circuit board and also melted the clear plastic encasement. Nothing else was wrong. I told him that I thought it was caused by a lose ground connection.
- General Interest
- Car Audio
- Crunch PZX1500.1 power terminals
