Crown XLS 802
It seems that there is LM 339 involved in those two leds Replaced that since i have seen them fail often in VU application especially in the VU of the Sanyo plus 55.
No change .
Problem is that LM 339 is nowhere to be seen in the existing schematics available in the network. Either its a different version ( mine is xls 802 D ) .
Next step is to advance my troubleshooting based on the known operation of the 339In between if someone can come up with a proper or complete schematic i will be more than glad to have
thank you !
Kind regards
Sakis
thanks to a guy called Kip got my shelf a compete schematic helping me understand the principal of operation of the 339 at this application.
Problem in the amplifier was the reference of clip common for both amplifiers since this is coming from +Vcc .
Obviously my initial guess was correct and one simple resistor that provides the clip reference was totally open like others that i have found in the past in XLS series
R159 150K was found guilty !!!!
Kind regards
Sakis
