Hi,I need a bit of help with a crown k2 that I'm trying to repair.the problem is that the amp seems to be power cycling,when feeding a signal the signal lights will glow brighter as does the power light but then the audio cuts out and all lights dim as if the amp is going to sleep but then will kick in again randomly.
I put a link in to bypass the sleep circuit but the problem persists
I removed the input board and there is nothing obvious.
Any help is appreciated
Haven't had a chance to look at it this week,hopefully get some time on it in the next couple of days.
The last time I looked at it I found a suspect resistor and a couple of caps but didn't have time to investigate further.
I read some where that 100uf caps either on the input board or main board are the first to let go
I will update when I get any new info
