Hello,
My first post here, seems like a really cool board.
Anyhow, I have a question. I have a mobile amplifier which has an onboard HP/LP crossover variable from 50-200Hz. What I need is a point in the 600-900Hz range, so I was thinking a crossover x10 multiplier switch might work giving me a range from 500-2000Hz. Several amplifiers/crossovers use them, Im just not sure exactly what it is.
I recieved a tech paper a while back showing how to do the mod on a different amp, but I deleted it a while back accidently. It was just a simple resistor swap. I searched here, but didn't come up with much. Any chance someone here would happen to know how to modify the crossover section to achieve a x10 range?
Thanks for any help.
Well I wish I had one but I dont. I'll see if I can get one, but I doubt it will happen. I have a pic of the board if that helps any, but it is too big to post in this forum.
I could send it to someone if they are willing to help, or I will try and get ahold of a schematic.
Thanks again.
Thanks again.
