Crossfire amp help please cfa-602
there is four diodes in spots d801, d802, d803, d804 two negative and two positive they are fine as well, two of them send voltage to the two caps right next to them and two go back to the gray body and black line diodes d106 and d107 not sure what kind of diodes those are.
Post the DC voltage on all 16 pins of the power supply IC. Place the black meter probe on the amplifier's ground terminal. Place the red meter probe on the point where you need to measure the voltage.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
