there is four diodes in spots d801, d802, d803, d804 two negative and two positive they are fine as well, two of them send voltage to the two caps right next to them and two go back to the gray body and black line diodes d106 and d107 not sure what kind of diodes those are.
http://www.diyaudio.com/forums/gallery/showphoto.php/photo/6511/ppuser/162317
Here is the trace of the n fets all look the same
should I remove those drivers for the 718's and power the amp up maybe eliminate some possibilities
because I am only gettting .96 volts on the gate there is a short somewhere, here is the gate pin nine is flat unless i go way down on volts division.
Picture_004 - My Photo Gallery
Post the DC voltage on all 16 pins of the power supply IC. Place the black meter probe on the amplifier's ground terminal. Place the red meter probe on the point where you need to measure the voltage.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
- General Interest
- Car Audio
- Crossfire amp help please cfa-602
