Hi
I have a Crest VS 900 amplifier that has developed a rather nasty problem. It has a positive waveform clip and goes into protection upon signal being applied to either channel. It seems to have a DC offset problem also. If the signal is applied very very slowly I can get several volts out into the 8ohm load before it goes into protection. The positive waveform is totally clipped and the negative is fine. I cannot get a schematic for it so I am asking if someone has had experience with one of these. There seems to be a STK module in the circuit that I assume is part of the front end, but this is a guess.
Any thought here would be appreciated.
Joe
Joe
