For a first post that's pretty amazing to argue with someone who has been gone over 2 years. Let's see where he goes next...
It is unlikely that with such a large distance between the conductors, the humidity of the cotton as in the air will have any significance.what happens when the humidity changes?
water is highly polar, relative pemtivitivy ~ 80
even polystyrene dielectic loss increases ~10x with its miniscule <0.1% equilibrium water absorbtion
quick search finds: "Cotton can absorb about 25 times its weight in water"
although only the 1st 5-6 % of water molecules by wt % are bound directly to the cellulose free hydroxyl groups
A first and so far only post, that starts off with an incorrect fact, but then states the usual regarding electronic noise... I await the follow up with baited breath.
EP0608413A1European Patent Office
When used with music reproducing apparatus of high quality, a transmission cable according to the invention contributes to music, which distinguishes itself to experts by a remarkable "three-dimensionality", just because of the excellent transmission properties on the lower levels.
EP0608413A1 - Electrically conducting cable with one or more cores, in particular for signal transfer
- Google Patents
- Google Patents
Where do you find 28-30 AWG single strand silver wire nowadays from a reliable source? I found copper from Farnell:
https://se.farnell.com/pro-power/ec...copper-transprnt/dp/1230976?st=0.25 mm koppar
and this local place I have never delt with:
RS PRO Single Core 0.25mm diameter Copper Wire, 1100m Long | RS Components
And then some DIY shop - I wouldn't know for sure:
30awg/0.25mm High Purity Soft-annealed Silver Wire and Teflon Piping – DIY Hifi Supply
Vacuum State - High End Hifi Equipment
if you don't bother ptfe individual coating for the conductors, here is a good source for high quality UP OCC single strand silver wire in Europe :
NEOTECH SOST-26 Fil de cablage UP-OCC argent pur monobrin PTFE 0.128 mm2 - Audiophonics
NEOTECH SOST-30 Fil de Cablage UP-OCC Argent Pur Monobrin PTFE 0.0509mm2 - Audiophonics
Best regards
nar
Best regards
nar
- Member Areas
- The Lounge
- Cotton OCC 5N Silver Interconnect Cables
