no problem, but I posted the code already, right?@IVX,
Ivan, will you be able to share the test recording and matlab script? I'd like to try and see if there is a way to make an algorithm which can run on PIC32 USB transport.
Which record do you need? Music signal or something else? Actually, you can make your own test signal with Audacity, Cosmos ADC is too good and behaves like sinth signal with almost no noise. If you gonna use cheap cascaded ADCs, it would be better to refine my code accordingly.
yeah, as a picture 😀no problem, but I posted the code already, right?
One you load in your script.Which record do you need?
I have the Cosmos ADC but since there is a recording done by you, it would save me some time assembling the setup and making the recording.Actually, you can make your own test signal with Audacity, Cosmos ADC is too good and behaves like sinth signal with almost no noise. If you gonna use cheap cascaded ADCs, it would be better to refine my code accordingly.
