corner soffit mount speakers
up to what frequency should i expect a boost?
It would work up until the wavefront doesn't cooperate with the room corner. The design process is involved. Why don't you put the speaker in the corner and work from there. Your tools will be the soffit itself -- extension/translator, however you want to see it, can try to make it fit.
i was planning to do that to see how it sounds.just waiting for a friend to come move around the furniture.
These are some of the first speaker I built. Curt Campbell's Triune.
TriuneTL_07
They are still in use for my wife's HT setup as surrounds
Curt designed these as main speakers and as a center channel. The off center tweeter will help with the diffraction signature of the vertical MTM main speakers. The tweeter offset carried over to the horizontal configuration.
Here is a concept to consider. Its a SEOS12 and compression driver with a 12" woofer structured to aim down from a ceiling corner. I never built it; I got interested in Synergy horns instead. If you did build it you would probably want absorbers on the walls and ceiling immediately adjacent to the cabinet. There is enough cabinet volume there for bass reflex so with the right woofer you could have response down to ~40 Hz.
Something else to consider would be Bwaslo's Small Syns built into a box shaped like this but that would mean taking on a more complex crossover
