Converting a DAC
harrygrey382 said:
could this be right behind the button and display area?
The important one that you will need to find will most likely be on the main board....with a lead from the display/control panel connected to it.
stoolpigeon said:
SAA7350 + TDA1547 is what became known as DAC7 and is a fairly ordinary performer, majoring in blandness, IMHO.
It has already been suggested that one possibility is to exclude the TDA1547...and use the SAA7350 as the DAC.
