Connecting another bridge rectifier to an existing V+/V- supply
I need another V+ from the new bridged rectifier to power another circuit.
it might best explained with a diagram.
- I currently have the V+/V- supply in the diagram.
- I need to tap into the transformer to power up another circuit (lower portion of the diagram with the bridge rectifier)
- The transformer that I'm using have 2 secondaries connected in series. The connected wires become my center-tap ground.
Is this possible? If yes, what changes do I need (if required) to make it work?
Thanks a lot.
PS. apologies for the quality of the diagram. It's a mashed up I made using MS Paint. 😀
Edit1: I thought just came to mind. Instead of tapping into the transformer, perhaps I can tap V+ from the first capacitor immediately after the existing rectifiers?
Edit2: the existing supply is a regulated +/- 12V. The new supply will give me more than +12V.
Edit3: The 2 grounds from both supplies are not connected.
I am not completely sure what you want to achieve when you say "I need another V+ from the new bridged rectifier to power another circuit".
But to try help you describing your requirement, then please explain, why you do not just use the existing V+ as described in your edit?
That would give you a V+ (referred to ground).
BTW: Is it intended that the added bridge rectifier does not include a smoothing capacitor? - because as the circuit is drawn now, you will just get a rectified AC with a peak value that is the same as the voltage difference between V+ and V- (that is: 2 * V+).
Cheers, Martin
Reactions: mrjayviper
Edit: I thought just came to mind. Instead of tapping into the transformer, perhaps I can tap V+ from the first capacitor immediately after the existing rectifiers?
It looks like the sensible solution: as the previous poster remarked, your proposed scheme will result in fireworks.
If you really a "separate" supply (why?), simply duplicate D1, D3 and a suitable filter cap
You cannot connect the 2nd bridge like that....boom....
I forgot to mention the ground for the 2 supplies are not connected. Does that changes anything? Thanks again
WHAT is the second load?
WHAT voltage does it need?
Not strictly necessary but to help clarify things, WHAT is the DC voltage between +V to 0V and -V to 0v?
Now that we are at it, WHAT us the original voltage load or what is it feeding?
Please answer all the "what" questions?, otherwise answers will easily contradict because of lack of definitions.
PS:you say "grounds are not connected", I am not so sure about that.
Also not too sure you understand "galvanic isolation".
If no graphic software available, just draw with ink on a piece of paper and upload a phone picture.
Reactions: Osvaldo de Banfield
If your new load is relatively light, you can isolate AC path via two large bipolar capacitors in each AC arm of the new rectifier added. Then, reference it where you need in order to obtain the new proper voltage. Those parallel lines means the new cap to be added.
