NO "science"-)
YOU introduced the "science" - remember the "short film clip"?
Nice that you recognize the "short film clip" as "science", or representation of "science"-)
Your "science", not mine.
Cumbb, in the past, you said you used inverted commas as a vagueness marker, indicating that there is scope for interpretation.
It appears you are the master of vagueness! 😉
Stick to the Electrophysics, cumbb.
Then I can share my expertise on topics such as magnetically confined plasma, high power sources of coherent and pulse radiation and the interaction of radiation with plasmas and solids, nonlinear dynamics and chaos, lasers, nonlinear and quantum optics, quantum dots and nanophotonics, optical communication and computation, plasmonics, solar energy conversion, bioelectromagnetics, magnetics and spintronics.
I'd be more interested in how electrophysics explains the problem of rotating galaxies, as you have claimed in the past.
I'm feeling a 'Voodoo magic, man' moment, courtesy of Predator 2 coming on...
Not that it makes it anything other than a catastrophically bad film, but the moment is a priceless one [alas, 18 rated given the language, so I'll refrain from posting a link to the clip], and worth reflecting on at moments like this.
At least we should see a quote!
Gold Tooth:
King Willie says, not only do I have to kill you, but I have to take your soul. Voodoo magic. F***ing voodoo magic, man!
Gold Tooth:
Easy - because if everything in that sketch is true, it's probably dead.Why does a TO-3 case sound different, if it has been modified as shown with the picture?
Anyone making that kind of modification to a TO-3 cased part in the interest of making it sound better does not inspire confidence in what they say about how resistors and capacitors sound.;-)
Why not more interested in this thread:
The only TO-3 mod that makes any sense is this one. Other than decapitation, which is just the iron clad test of whether a batch is real or fake. The idea was to prevent a loud BANG when 65V gets applied to the heat sink. It was a tight fit.
- Member Areas
- The Lounge
- Components-forms do affect signal, sound? A response offer:
