CMOS OpAmps gate stoppers?
I have no idea why someone came up with the notion that opamps need gate stoppers.
Ha, ha. Too many threads here end like a ‘broken telephone game’ where initial message is changed with every next post.
  • lineup asked only do we need input resistors with CMOS opamps, like is usually seen with FET ones. Their purpose was not named.
  • Osvaldo da Banfield named them stoppers, assuming their function.
  • I pointed out that we need to limit input current because of ESD protection diodes.
  • tomchr elaborated on ESD protection.
  • JMFahey expanded with example of protection for hard working conditions.
And the ball is rolling. Who knows where it will end. 🙂
Reactions: PRR
I own a portable shortwave radio that is infamous for its input JFET being blown out by ESD to the antenna.
Even the high-gain bipolar transistors used in audio have a base current rating of only 10mA.
I would say that ESD protection is a good idea for external inputs.
Internally, series resistance is not needed.
Ed
Because of usual ESD protection diodes, it is necessary to use input resistors for limiting input current below datasheet specified max. value. In case of OPA1656 and most TI opamps, that is 10 mA. I know from practice that 30 – 50 mA short pulse current doesn’t damage protection diodes.
Before mass production starts, a couple of samples are subjected to worse abuse than that:
During latch-up testing, usually 100 mA is forced through each input for a couple of milliseconds while the chip is at the maximum allowable temperature.
A current of 1.33 A that decays exponentially with a 150 ns time constant is forced through the inputs and outputs with the chip at room temperature during human body model ESD testing.
A couple of amperes flow during a few nanoseconds during charged device model ESD testing.
Reactions: tombo56
It is good to realize that the purpose of 'gate stoppers' has absolutely nothing to do with limiting input currents.
'Gate stoppers' are used to enhance stability, to avoid oscillations from input pin capacitances and wiring induction.
The resistance should be kept as low as feasible for stability. Values between 10 and 100 ohms are often used, but it is hard to give an absolute value as it depends on the physical implementation and parasitics.
Jan
Agree completely. That's what they're for.
Did the thread not start saying "CMOS OpAmps gate stoppers?"
The ones I've seen and used are to prevent spurious oscillation (at RF frequencies and causing RFI) that I've seen happen in a power MOSFET circuit, due to input capacitance and I presume spurious inductance and such. I saw this in a data sheet decades ago and added 470 ohm resistors right at the gate terminals, and that fixed it. I presume the name came from stopping the device from oscillating. These had nothing to do with preventing gate damage, as others in the thread were discussing for other uses of series resistors. With static inputs that are likely to cause damage, 470 ohms would likely not be enough to prevent it.
Looking only at the content of first post, and forgetting the title, I supported my ‘broken telephone game’ claim by example. Did I not? 😆
We are her for hobby and every word is not carefully measured with preparations adequate for a dissertation.
Most resistors at the opamp inputs are there for other reasons than as stoppers. I’m fine with one resistor providing several functions.
The measured performance also improves when you leave out RF filtering and external ESD protection, as long as there is no RF interference (or ESD) in the measurement set-up and the circuit stays stable: flatter frequency response, less phase shift, less noise...
The problem is the Miller Effect. In a single MOSFET it toghether to parasitic inductance and large di/dt may cause ringing of such value to destroy the thin gate isolation. But OPAMPS has very little Miller capacitance, very little current in them to cause them oscillate or breack down of input gates.
Utopia/lab conditions don't guarantee normal expected operation at home which is IMHO what really counts. Still many here seem to like such designs and their peculiarities.
Reactions: JMFahey
