That's funny, a TEG (thermoelectric generator) on one side of the heatsink, that feeds a TEC (thermoelectric cooler) on the opposite side of the heatsink.
With a fan needed on both the TEG and TEC, it's sure to be a hot success. Oh, don't forget to power the fans with the TEG.
Hi
Are actually some ideas to get the heat back (Seebeck Effekt) from the overheat of an class A or A/B Amp..?
sorry it souids strange/stupid... but.....😀
Thermogeneratoren
I'm willing to bet a Telecaster through a 50 watt TDA7294 and mic'd through the PA would sound nice and retro, the old Blues days.
Thank you for pointing me to the 10uF Wima capacitors. They are both decent in size and price.
I only looked in my storage and found some 2.2uF that were already pretty large, so, I concluded that 10uF would be too large to be used on a board.
I was wrong in that assumption.
In a later post (different thread it seems) you write that you called your wife in as second opinion on the TPA325x amplifier. That is a clever approach because wifes, mainly being concerned about that we do not leave our electronic stuff all over the place, normally do not have a prejudice on performance issues and see it much more from a layman's perspective. If she also agrees, in comparative test, that the TPA325x is better I am close to buy one myself. At least it will give me some basis for disturbing in the discussions about how much better it is than the other class D chips.
Hi
Do you have experience in performance /sound for special good caps for class D? e.g. Elna Silmic II or the Nichicons "Muse" serie (UKZ or UFG).......
This fine FXC502S Pro or a sepcial board, e.g. because
Which do you want to buy, i looked exactly at this board
MINI HIFI TPA3255 300W + 300W Class D audio Digital Amplifier Board DC50V -in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
They might have chosen a 10uF ceramic smd cap because the value is big enough it might offset whatever sonic artifacts a ceramic this size possesses? Maybe a through hole regular film cap can be smaller?
My wife has better ears than me, she's just not using them. I have better eyesight, but she is better at finding mushrooms in the forest. We are probably trying to compensate for our lesser senses.
If she says the TPA3250 is better than the TPA3116, without me asking about it, then i'm happy I was not under some form of bias.
somthing like that !! sorry for german web page...
Energy Harvesting: EnOcean: Warme als Stromquelle | Markt&Technik
search for Thermo Spintronik
Hi
I know better audio electrolytic capacitors exist, and I have some in my lab, but I cannot say how much better they are.
My candidate board is this:
,which should be exactly what you suggest.
Do I need it? - no. Do I want it? - yes. As a Dutch girl I knew once said: "The only difference between boys and men is the price of their toys".
no comment 😀😀😀😀😀
Depends by 95% of the the man at the fretboard😉I'm willing to bet a Telecaster through a 50 watt TDA7294 and mic'd through the PA would sound nice and retro, the old Blues days.
by the way: I would bet a strat played through my TPA3118 stage amp can sound nice as well
I'm not the first to notice those TDA7294 amps do sort of sound a bit like an old tube amp.
I was thinking of a tube preamp to go with it. I also want to try a gang of 1 TDA729X amp per speaker in a 2x10 or 4x10.
In reply to questions about class D crossover distortion:
This is governed by selection of switching frequency and output inductor value. A proper 250W/8r class D amplifier can have as much as 50W of class A before crossover distortion arises. Proper dead time results in no substantial increase in THD past this power level and until 3dB below clipping.
In quality class D (AD modulation) crossover distortion is not a single dead band around 0A current output (like class B or AB), it is 2 dead bands around "+i" and "-i" amperes output current, where "i" is the amplitude of the current sawtooth biasing output inductor (it can be calculated from +V/-V rails and output inductor value, i=(V/L)*0.25/fsw, for a 22uH inductor, 50V and 250khz: i~=2.3A, about 20W/8r of class A).
Hi-Fi class D shall not be mistaken with boombox class D.
That reminds me. I don't recall using an output inductor in that project where I tried to press a class AB amplifier into class D service.
How about reverberations or sound from another channel moving the speaker cone, generating signals from the voice coil, and confusing the amp about zero if any feedback system is used ? That could make about any amp oscillate or do strange moves to put it's self at zero.
A post-filter feedback self-oscillating modulator with single integrator can achieve under 0.01ohm output impedance across the audio band. This is a damping factor of about 1000 up to 20khz.
For these modulators, cross-talk intermodulation is mitigated by trimming all channels to oscillate at same frequency when idle. With 2 PCB construction (modulator+power) 100dB channel separation across the audio band is attainable.
Of course there are simpler ways to do class D, but performance suffers.
Here is a photo of my new Dx amp running on two 19v SMPS bricks for dual rail:
You are using the famous unbranded 8$ "Digital to Analog converter" as a DAC?
One aspect, cooling.
High power! Efficiency of TDA8954 around 90%. Efficiency of class AB around 70%.
Cooling 35W off a TDA8954 (HSOP24 SMD housing) is somewhat more difficult than some (2x)100W distributed on 12 TO-264 housings.
So, unless you have the DBS23P housing for your TDA8954, I would take that into account.
In practical use, it's even a worse difference than that. Those figures are at full sinewave power, a point that is virtually never reached in a decently designed system. Average power to a speaker in most home stereo systems isn't even a single watt (!), and "average" is what counts for heat. The efficiency of class D at that power level (assuming an amp rated for higher power, say 50W or more) is very, very, much higher than a class AB amp.
There is a huge difference between the various class-D implementations. Far more noticeable then between various class-AB amps. There is no universal 'class-D sound'.
In my experience properly designed amps with the IRS 2092 / IRS-20957 and now the new TPA3251 it is hard to hear differences compared to a good class-AB amp. There might be some difference when the output level is very high, close to clipping.
On the other side, some of the older class-D chips have close to 1% distortion above 10 kHz and don't sound good in critical listening.
For the ready to use boards in the market, I like the 100% iraudamp7s clones, they sound good, don't black-out the neighbor's TV reception and have lots of power. Their noise level is a bit high so less suitable for very efficient speakers or near field listening but great for anything else. There are also a few really poor boards with the IRS-2092 available on-line, so some checking is needed before buying.
The TPA3251 has far less noise, but I'm not aware of any 'ready to use' boards with this chip in the market.
Hopefully helpful.
I am fully agree with you
Every class D designed by different person has its own unique sound.
Even change inductor from different brand it may has different sound.
The point we cannot generalize all class D. But must be a specific product.
I
Ha..ha.... this is the best statement 😀
All I can give is my experience. I went from an expensive 7.1 pioneer surround reciever, with all Paradigm speakers, to a TPA3116 based class D with 2 Paradigm Titan V2 speakers and a powered Yamaha sub. When listening to music there is no comparison. The $75 Class D Kicks the $1000 surround amp for music quality all day.
- Class D
- Class D vs Class AB
