Funny, I just experimented with thick cardboard frames around my 2-way Dynaudio near-fields.
I was really surprised - it felt like I was getting way more information from the recording. I think I might investigate wide baffles more in the quest of Accurate Mastering Speakers. 🙄
Any crossover gurus around ?
I want to substitute the T25CF002 with the T25CF001 ?
Would I need to make any changes or straight swap ?
I am far from a guru, but yes I think you would need to adjust the crossover. The two tweeters have slightly different responses, so you would need to move the crossover point to get back to a flatter response.
Also, the Fs of the T25CF002 is higher, so the crossover point would also need to be moved higher.
Here is some more information
Beveled Wide Thor -- just before the sanding sealer is goes on -- well, it's not a Thor anymore -- filled up an entire shop-vac with MDF dust:
after i put the sanding sealer on I realized that the humidity is a trifle high today --
as you can see I didn't baffle the top edge -- the thought of all those compound angles was giving me a brain-ache -- I am told that this can be automatically "figured out" in Solidworks, or VirtualMill however.
I doubt it'd make much of a difference to be honest. There's a limit to the value of worrying about everything. In double blind tests, I've seen Wilson WATT / Puppy 7 owners fail to identify their beloved £20,00UK speaker from a clone costing ~£2000. Draw your own conclusions.
Well, here's a first test -- as #1 son hasn't yet picked up the DuPont Centari auto paint so these things are still MDF brown -- I ran a test in the back yard -- this is 1 watt, 1 meter -- obviously there's some adjusting that has to go on. FWIW the internal volume is around 5,100 cubic inches -- 36 inches long with a rhombic prism of approximately 141 square inches -- I used 0.35 #/ cu ft of polyester fill:
when I cranked these babies up at 31.5kHz the crickets and cicadas started chirpin' their legs off:
sorry, no anechoic chamber
Are you using the crossover that comes with the kit, or did you make/mod one?
Looking at the graph of the W18 it looks to me like the bottom end was really helped out. Looking back in time...
Back in this thread...
Your result seems to most closely match the fat thor with the slight ripple. FWIW fat thor's internal volume is about 6250 cu in.
And a stupid newbie question about measurement in general. After the cross over point moving up, aren't you really just measuring the tweeter's on axis response? Since the boxes and BSC wouldn't seem to matter. I noticed you cut your chart off at 1000 and was wondering if that was the reason.
And one more, what are you using to measure? I am close to finishing my short thors and wouldn't mind trying to get some simple numbers. I am curious to see about room gain as my living room is theater shaped. And mostly I just want to fidget.
imjatse said:I am curious to see about room gain as my living room is theater shaped. And mostly I just want to fidget.
Obviously you haven't taken your Ritalin yet 🙂
The pair of woofers continue to put out well past 1kHz -- I was just trying to show the dips at 80 and 250 Hz.
I used the xo's from Madisound since I have them in hand. instead of white noise I used the Boonton to make 1/3rd octave measurements and set output of the amplifier precisely -- measuring outside is a PITA, but that's all I can do. my SPL meter can take RS-232 instructions which will make this process go a lot faster.
Scottmoose said:Nice work indeed. Now the killer question: what do they sound like?
while I have the second cabinet built, I want to build a bona fide THOR cabinet and perform the same test as illustrated above.
as exepected the Beveled Thor is in need of some serious baffle step correction -- the tweeter output rises to ~97dB -- hot enough to fry an egg.
I'd suggest turning the speakers over, woofers down closer to the ground plane to get another perspective. There is probably some ground plane cancellation going on there, as you probably know. Mic at the same location and also on the ground plane would be interesting.
Nice work,
Pete B.
Nice work,
Pete B.
jackinnj said:Well, here's a first test -- as #1 son hasn't yet picked up the DuPont Centari auto paint so these things are still MDF brown -- I ran a test in the back yard -- this is 1 watt, 1 meter -- obviously there's some adjusting that has to go on. FWIW the internal volume is around 5,100 cubic inches -- 36 inches long with a rhombic prism of approximately 141 square inches -- I used 0.35 #/ cu ft of polyester fill:
ok, measure along a ground plane -- microphone 2 metres from the source...as per Dickason...I may have to wait a couple weeks to do this as the DUT is being painted.
well, the boxes now have 4 coats of Dupont Centari Black -- on top of a 2 coats of Dupont primer -- Centari is a 3 part paint used for auto body shops -- we use it on airplanes. the paint needs to cure for another 24 hours at least:
well, I haven't yet figured out how to position them -- they sound great -- I suppose that they will do a nice job of loading the 40 foot chimney right behind them -- some domestic issues to take care of as well.
Very nice! Those look great. I really need to find the time to finish mine. Did you place the ports towards each other, or away? Nice job!
- Clarity on Seas Thor Kit
