seppstefano said:BTW, should you know how to biwire a Dynaudio Contour 1.1, please let me know
Welcome to the forum...
As to the Dynaaudios, if they are not already set up for bi-wiring/passive bi-amping, then you would need to map out the crossover as a start.
dave
Thanks Dave
Ciao Dave,
thanks a lot for your kind answer and for such a nice Forum.
The Dyna have only a pair of post and an OCOS cable input.
That's why I'm just looking on the web to get Dyna xover schemas, but it doesn't seem an easy task...
When possibile I'd like to know before opening them
Ciao,
Stefano
Ciao Dave,
Ciao,
Stefano
Re: Thanks Dave
When i get a new set of speakers, opening them up to see what is inside is one of the 1st things i do :^) -- electronics too.
dave
seppstefano said:When possibile I'd like to know before opening them
dave
SUB is fine
Hi all,
the SUB is sounding preety cool, powered up by a HK/870 and eq'd by a Behringer DSP.
I'm quite happy
Now, next steps will be to build the second one, and to open the Dynaudios to check the quality of components.
Do you think that a cap replacement (pgrade) would be worth the effort??
Ciao,
Stefano
Hi all,
I'm quite happy
Ciao,
Stefano
- Member Areas
- Introductions
- Ciao everybody!
