Probably an LCD display with a back light.
Fleabay meters are so cheap, why not just replace it.
LCR-T4 Transistor Tester Diode Triode Capacitance M328 ESR Meter MOS PNP/NPN UK | eBay
These meters come at lots of versions with various LCD controllers [transistortester] Index of /Software/trunk
I agree that getting a new one is the best solution.
It is such a shame that sourcing specific spares is so difficult and expensive if at all feasible. In my experience from repairing things of great age, that most spares are not available.
With old valve equipment, there is always someone with a valve somewhere but for LCD displays it is not likely to find a replacement of the same type, let alone with similar connectors.
IMO the product price must be considered. We could hardly buy this very useful device for such meagre price if the manufacturer (IMO one person somewhere in China who contracted the board production and assembly) had to use only parts with guaranteed long-term availability.
Maybe ecause of corona, sending it takes ages.
I have found the dispay type, and have it but has a different cable attached to it missing some connections.
regards
Agree
I like repair things, we have in holland a commercial on tv about that, unfortanely it is dutch.
YouTube
translated
APPRECIATE IT. REPAIR IT
We throw away a lot of valuable things in the Netherlands. Almost 10.9 million kilos of electrical appliances and textiles are discarded every week. Stuff that after a small repair can often go well. With the campaign "Rate it. Repair it ’, SIRE wants to encourage as many Dutch people as possible to repair their broken items. Whether it is a leaking coffee maker, a broken suitcase or jeans with a hole.
IMO it is this build T4
https://svetelektro.com/modules/For...id=73891&sid=be39da11a435a9bcf40ce9b4c2f07233
i.e. SPI ST7567 LCD LX-1284B
e.g. http://aitendo3.sakura.ne.jp/aitend...d/fstn/LX12864BA-1/LX-12864B2_V10_aitendo.pdf
readily available from China
IMO the pinout on the picture suggests it's version LX-1284B5
lx_12864 - Search -
EasyEDA
12864 Character Dots Graphic Matrix LCD Display Module Blue Backlight ESR METER module-in Replacement Parts & Accessories from Consumer Electronics on AliExpress
lx_12864 - Search -
EasyEDA
I made a pic, so you can see what the problem is, that is the flat cable. The right one on the pic is the proper one, left is wrong, I have these. Did look at LX-1284B5 these looks closer to the original.
There are many variants of the LX-1284B LCD, just search easyeda.
Look at the B5 version - 14 pins, the not-connected (and VB0+/-) pins fit your layout. But I very much doubt you can get it outside China, they make all that stuff there.
And even with the correct pinout you have to pray the LCD controller will be compatible with the arduino firmware flashed in your tester.
The LCD will likely cost you as much as new tester.
I did find these B5 but not the right connections, one pin missing.
2.4 inch 128x64 12864 dot matrix cog lcd-schermmodule met blauwe achtergrondverlichting Aanbiedingen – Banggood.com|Shoppen Nederlands
I did had order one and get it in quite short time from banggood to holland, 4 euros.
But the seller did give me a proposal, order another one for half the prise, I had already get half of mony back from him, but I like reparing also, climate protection hehe..
That one (if the picture is correct) is 10pin HSG12864-34 http://www.lummax-ele.com/Uploads/Download/20160714/HSG12864-34-YTDSG-R_A1.pdf . The B11 stated in the description has 12 pins, B5 has 14pins. It is just a different pinout, you can easily make a simple adapter.
IMO you need B5 discussed e.g. [Solved] LCD LX-12864b5 can't find any information | AVR Freaks
a adapter for this is not possible, it is soldered under the lcd, and needs to be flat.
oke thanks, I go look.
- Design & Build
- Equipment & Tools
- chinese meter for cap,s coils, transistor etc.
