Cheshtap Power Amp
hi irvynjay and andrewlebon,
pls guide me.
1-when first power up two led's lights on in the driver board,
2-i set dc offset to omv with the 500ohm preset.
3-i set the bias preset to half turn ,
4-protection section working with 12v dc,
-active led is on, when the 12vc power given,
-protection led is on, after relay active the led is off,
-when power off the amp, the clip led is light on and slowly off,
5-i provide signal to the amp, but out signal not comming, what will be the problem?
here is the new images,
supply voltage 50-100-0-50-100vdc.
