cheap project in the UK
Hi Vk,
hold your horses a minute, my problem is I don't have
any measuring equipment (except my ears of course).
Using a test CD basically the midrange / lower treble
is all over the shop (presumably due to poor integration
and / or uneven midbass unit response).
The units don't look too bad, £25 for two standard 19mm
tweeters, two 4" midbass units, two nice looking boxes
and an active amplifier doesn't seem too bad to me.
(I'll improve the boxes if I can improve basic performance)
I've inserted some foam acoustic damping (there wasn't
any), and detuned the ports (foam lining) but still the
bass is a litttle strong / underdamped around 100Hz.
With measurements the c/o design shouldn't be too
difficult as the amplifer has bass (for bsd correction)
and treble (generally useless) tone controls.
:) /sreten.
Manufacturer page on these speakers for ref: http://www.microlab.com.cn/en/product/speakers/2.0 SERIES/B-73.htm
These 2-way speakers from microlab feature top notch materials and high quality construction for unmatched fidelity in computer speakers. The wooden cabinets are made from 12mm (1/2 inch) MDF for low resonance. The 4" ported woofer provides punchy bass with a rubber surround that won't rot away like foam or paper and the 1" semi-dome tweeter ensures crisp highs. The built-in 12WRMS amplifier has an external heatsink to shed excess heat, and features high quality volume, bass, and treble knobs. Overall, these are great speakers for the money and you probably won't find a better value in computer,DVD,TV,home theater speakers.
And they're made out of 12mm MDF!
Vikash said:
I think he meant drone perhaps? As in to even out the internal volume I would suspect.
Hmmm... the possible problem is the cabinet is too small or the
basic Qts of the driver is a little too high causing the excessive
bass behaviour around 100Hz.
Either way you don't want to be reducing the internal volume
if you can help it. I'm quite happy to have slightly different
bass alignments left and right - least of the speakers problems.
Vikash said:
Anyway, I couldn't resist playing and ordered a pair.
good man !
:) /sreten.
Vikash said:
Considering the price, these are some heavy, nice looking 12mm MDF cabinets. They sound pants.
I did say they didn't sound hideous - :D
Vikash said:
Dare I say it? Might be worth considering the AP100Z0 in these cabs Rb.
I'd certainly consider it if I had them lying around.
Vikash said:
I'll try and take some measurements this w/e and then we'll just see if we can make something out of this cheap buy. ;)
Well out of the box there is no internal acoustic damping, very
thin wiring, probably misaligned reflex tuning and simply put
the nastiest (if its not suitable) c/o possible.
I'll take mine apart this weekend to investigate options further,
I'll also report on the effects of full acoustic stuffing on the bass.
Any complex eq required I'm planning to be at line level, so its
a question of integrating the tweeter and midbass in the box.
:) /sreten.
I've taken them apart and some notes follow :
1.The drivers appear to be perfectly servicable. The tweeter is
a version of the Audax 12mm dome/cone - should be fine. The
mid/bass unit is paper with a magnet as big as will practically
fit. The voicecoil is vented and stiffness seems to be about
right for reflex loading (i.e. Fs is not too low for reflexing).
2. The amplifier consists of two boards and the transformer.
One board cintains the two IC amps and the power supply.
The other board is an entirely passive pre-amp. It should
be very easy to modify the tone controls for BSD or similar.
There is enough room between the boards to add a
couple more smoothing capacitors to the power supply.
:) /Sreten.
Pic:
